LS on factory air camber adjustment
Old 03-08-16, 05:11 PM
98sscamaro
98sscamaro's Avatar
Default LS on factory air camber adjustment
Hey everyone. I have been seeing and hearing conflicting information about alignments for cars lowered with air suspension. I was told there is nothing that can be done to adjust camber for tire wear on the cars with stock air. However, I have seen online that it can be adjusted with a smaller drop on the air. Does anyone know what is true and what isn't?
Thanks for any help
Old 03-08-16, 05:36 PM
Dr. Jekyll
Dr. Jekyll's Avatar
More info bud. Lowered an inch? Lowered 5 inches? Front camber? Rear camber?
Old 03-08-16, 05:55 PM
98sscamaro
98sscamaro's Avatar
It has the data system air controller on it. I basically want to be able to drop it about an inch and have it aligned so that the tires will stop wearing out. Then just dump it when parked. The front and rear tires have worn out already and been replaced and now the fronts are wearing again on the inside.
Thanks
Old 03-08-16, 06:50 PM
Dr. Jekyll
Dr. Jekyll's Avatar
Okay then you shouldn't have any issues aligning it. If you go lower you will need the camber kit for the rear.
Old 03-09-16, 12:40 AM
Lextrician
Lextrician's Avatar
Drop an inch and get it aligned at that height..
Old 03-09-16, 01:36 AM
njumongkol
njumongkol's Avatar
shopfigs.com
Old 03-09-16, 09:09 AM
GR6RR
GR6RR's Avatar
^ bushings off-centered. Never thought they had this. I need to fix my camber. Was thinking to add washers/spacers to the upper control arms to push them out a tad so I wouldn't eat so much inner tire.
I may just try these bushings out, cost isn't too high to try.
Old 03-09-16, 09:14 AM
njumongkol
njumongkol's Avatar
t-demand.jp has arms too.
Old 03-19-16, 02:43 AM
98sscamaro
98sscamaro's Avatar
^^ Thanks. So it is true then that there is no adjustment on the stock arms for camber.
Old 03-19-16, 06:39 AM
1Putt
1Putt's Avatar
Yes you are correct
Old 03-19-16, 06:54 AM
lbintab
lbintab's Avatar
There's no factory camber adjustment for the LS460. What size wheel and tires are you using? I feel 22s with lower profile tires wear faster on a lowered LS. All that extra weight on the edge of the tire where the side wall is. Plus the load ratings on most of the tires you'll find for the sizes you need for this car are likely not high enough. I run 21s with a taller sidewall. My car is pretty low but it's always changing because of my air suspension so toe will aways be a little off. I haven't run into much issues with tire wear.
Old 03-24-16, 03:22 AM
broken_tsi
broken_tsi's Avatar
I have some rear arms for sale if you still need them.
Old 03-24-16, 11:56 AM
lbintab
lbintab's Avatar
Check your DM
Old 03-28-16, 03:05 PM
98sscamaro
98sscamaro's Avatar
I have 305/25/22 rears and 255/30/22 fronts. I am thinking about just mechanically lowering the car about an inch or so and then buying those bushings that were linked above that have some camber adjustment in them. I'm not sure if anyone has shortened the height sensor arms on an LS with factory air but I know people have done it with other cars that have factory air.
Old 03-28-16, 10:44 PM
lbintab
lbintab's Avatar
Yeah they make lowering links. It's been done. It's just that the car will never be quit equal height.
Shiryo
Wheels, Tires & Brakes Forum
03-02-13 11:44 AM
jediredeye
22
06-24-11 04:21 PM
EN_VY
Suspension and Brakes
19
04-21-10 10:49 AM
Scotguy
GS - 1st Gen (1993-1997)
01-03-10 04:27 PM
SH430
05-26-09 02:37 AM
Quick Reply: LS on factory air camber adjustment
