Startup Problems
Startup Problems
I just got my car back from Lexus and they did the whole you need to fix this and that fixed. They said I needed a new battery etc etc.
I took my battery to auto zone and they said it was working fine and my alternator was working as well.
I don't drive every day and I don't drive for long distances. I live in the South and it's been cold as well.
Every time I try to start it, it feels like the battery is dying. After I drive for 15 mins and then start it up again it sounds great.
I have NEVER replaced my spark plugs and It's an 08 with 68k miles. Is that my problem?
Thank you as always guys!
I was having the same problems and a new battery solved mines.
I'm surprised AutoZone said it wasn't the battery. Is this the original battery? If so, it's time for sure. My 08 still had the original battery when I got it. Lasted maybe a couple of months and then it went. Autozone diagnosed the problem and put in a new one. Been fine ever since.
FYI, I drove around today and my batter DIED. I let it sit for over an hour at lunch and it barely cranked. I took it back to auto zone and she said it was dead.
So I got some kind of pro ration on the previous battery and looks like my problem has been solved.
There's two ways to test a battery, with a scanner or a carbon pile tester. The scanner is much easier on the battery and you get a lot of "false passes" with it. The carbon pile will absolutely kill a weak battery and it will fail.
Glad your problem is solved...one other thing...these cars are hard on batteries and it takes a battery that is fully charged to crank these cars.
Pro rated is key with these cars, I believe I just bought a battery with a two year warranty and pro rated for four. My last battery lasted 2 years (Interstate).
How long have you owned it and any issues? All the car forums are bemoaning them, due to early failures and issues. Apparently ever since they moved production to Mexico. There's been quite a few posts here at CL with similar issues.
Original Battery...
I'm still on the original Panasonic on my 2010. The car was actually driven off the lot at the end of 2009. Still going. When I bought the car near Thanksgiving 2014, the dealer that inspected said the same thing ... "needs a battery." 1.25 years later, no battery problems.
I'd like to hear more feedback on the yellow tops as well though.
