Foglights on without Headlights? (2013+)
Old 11-05-15, 07:38 AM
jasone36
jasone36's Avatar
Exclamation Foglights on without Headlights? (2013+)
Hello,
I'm wondering if it's possible to turn on the foglights without the headlights on the 2013+ LS460. I understand it's not possible without modification on 2007 - 2012 models, but I'm wondering if anything's changed.
Ideally, I would want to run the foglights as "daytime running lights", preferably without modifications.
Any feedback would be much appreciated.
Thank you.
Old 11-05-15, 07:09 PM
Shibumi1
Shibumi1's Avatar
As far as I know it's the same as previous models.. a rewire would be necessary
Old 11-05-15, 11:07 PM
dal20402
dal20402's Avatar
Would love to have them come on with the parking lights, rather than the headlights, on the '08. They are most useful with parking lights creeping in the thickest fog. But I don't want to rewire and I don't have nearly the l33t h4x0r sk111z to make the change to the BCU.
Old 11-06-15, 12:14 PM
jasone36
jasone36's Avatar
Thanks for the responses.
I'm wondering if the dealer in the US can "program" the foglights to come on without the headlights (perhaps via the "C-BEST settings?)
I'm pretty confident that international versions of the LS can run their foglights without headlights (for example, I believe the SC430 in Japan could).
Old 11-06-15, 01:27 PM
jamodeo
jamodeo's Avatar
I have seen a picture of a 2013+ LS run their fogs without headlights on a model from the middle east on this forum.
I have also clicked on every. single. button. in techstream looking for a way to change this, or set the localization of the car to something different to get it to work (like europe, asia, gulf, or ROW.) I have been unsuccessful unfortunately.
The only way I could get it to work was running an "Active Test" in TS which turns them on for that active test, but after that they just return to normal operation.
-Joe
Old 11-06-15, 01:55 PM
jasone36
jasone36's Avatar
Jamodeo,
Thank you for the very insightful response. At least now we know for 100% certain that it's not possible on a US spec model.
Thanks again for the insight!
Old 11-06-15, 08:59 PM
jasone36
jasone36's Avatar
I ran across the attached picture showing an LS460 with the fogs on (while headlights were off), and that inspired the idea.
Based on the plate, this is certainly a European spec LS460, however.
Attached Thumbnails Foglights on without Headlights? (2013+)-ls460-foglights-on-while-headlights-off.jpg
Old 11-07-15, 08:51 AM
roadfrog
roadfrog's Avatar
Not possible on a Canadian market car either. Not only that, I can't even disable the factory DRL.
Old 11-07-15, 09:58 AM
aaauae
aaauae's Avatar
Any guide as in how to do the rewire ?
I know a guy here who did it without adding another switch
Old 11-07-15, 07:57 PM
jasone36
jasone36's Avatar
It would be interesting to see the "rewire" process, but I think it may be dangerous on an modern LS.
I'm concerned something may get fried, if messing with the electronics, and trying to rewire.
Old 11-07-15, 08:26 PM
roadfrog
roadfrog's Avatar
Nah..... lots of us have done custom wiring for all kinds of upgrades and mods...... everything from auxiliary lighting (LED lights) to remote start, to Nav bypass, etc. Electrics are electrics and the principals don't change in a Lexus.
Old 11-07-15, 08:45 PM
CRowe14
CRowe14's Avatar
Don't let RF fool you, he's just the DIY guru in these parts!
Electronics are no exception!
Old 11-07-15, 09:03 PM
jasone36
jasone36's Avatar
I appreciate the responses.
Custom wiring work takes subject matter expertise... I'd venture to say the majority of modern LS owners are not super knowledgeable on the fine-grain details of electronics on a complicated beast like an LS... but I'm sure there are a few (like RF).
Old 11-08-15, 10:19 AM
roadfrog
roadfrog's Avatar
LOL. Hardly.
I have NO background in mechanics, electrics, etc. I'm in Law Enforcement. I failed grade 8 electrical shop, and never took any classes in automotive. All I'm saying is, anything that can be done on a Chevy can be done on a Lexus. No magic involved. Youtube, forum members, etc can all provide you with the information you need. It's a 12 volt system.....pos+, neg-, fuses, etc. Same as any other car on the road.
Besides Crowe......weren't you the one afraid to dive into a DIY brake job? How did that turn out for ya??!!
Old 11-08-15, 12:05 PM
Devh
Devh's Avatar
The lighting system that activates both the headlights and fogs are most likely integrated by a solid state circuit.
You can get around this by simply powering the foglights independently using a switching relay, switch and don't forget the fuse. Add the switch in the compartment and you are done. You have to keep in mind that you will not have the fog light indicator lit when the switch is thrown.
I don't really care what you do to your car however It's considered a big faux pas to run with your fog lights in the daytime and proper etiquette of it's use only when visibility is affected. I don't know all the details but I do know there is a show off new rich stigma that is associated with it .
Quick Reply: Foglights on without Headlights? (2013+)
