best windshield wiper blades for LS460?
Factory inserts for the factory blades. I replaced mine shortly after buying the car. The originals had been on the full 7 years (LA/Sacramento car that rarely saw rain) and still weren't in horrible shape, although they had a few small cracks. The new ones work perfectly and maintain the look of the OE blades without buying expensive new blades.
http://www.ebay.com/itm/LEXUS-OEM-FACTORY-FRONT-WIPER-BLADE-INSERTS-SET-2007-2014-LS460-/331668109309?vxp=mtr
DavidinCT (02-02-24)
PIAA hands down!
you have to pay dearly for them initially, but they leave the driest surface i've ever experienced in a wiper blade.
Now after 12 months i'm just starting to see streaks again, but these have seen a lot of rain and a brutal last winter.
Replacement inserts only cost in the $8-$12 range...
[QUOTE=dal20402;9232534]Factory inserts for the factory blades. I replaced mine shortly after buying the car. The originals had been on the full 7 years (LA/Sacramento car that rarely saw rain) and still weren't in horrible shape, although they had a few small cracks. The new ones work perfectly and maintain the look of the OE blades without buying expensive new blades.
[url="http://www.ebay.com/itm/LEXUS-OEM-FACTORY-FRONT-WIPER-BLADE-INSERTS-SET-2007-2014-LS460-/331668109309?vxp=mtr"]Lexus Factory Front Wiper Blade Inserts Set 2007 2014 LS460 |
Thanks
Thanks
PIAA hands down!
Recently replaced my wiper with Toyota Sightline. Excellent blades and most name brands should do the job.
http://www.autoanything.com/driving-...A5789A0A0.aspx
this is one place that you can buy them from.
for the left wiper and cheaper than autoanything
for the right wiper and also quite a bit cheaper than autoanything
Also check out the different styles, i think they make 3 or 4 different types. Good Luck!
Lexus Factory Front Wiper Blade Inserts Set 2007 2014 LS460 | eBay
The factory Lexus blades are the best I've tried. PIAA are just as good, but really only just as good.
FYI, PIAA refills will fit in the stock wiper arm. No need to buy the whole arm.
Yep, almost makes me wonder if the OEM Lexus blades ARE PIAA blades. They perform almost exactly the same, fit in each other's wiper arms, etc.
Have any of you guys used Bosch Icon's on the LS? I used them on my old Audi and they were excellent. I've also used them on other cars in the family, but I don't think I've seen anyone using them on the LS.
Also, any recommendations for winter wipers?
I have used the Icons a bunch of times, nowhere near as high quality or long lasting as the OEM ones or the PIAA ones.
For winter, the OEM ones are a solid arm, they're fine.
