Loose Front Bumper
Loose Front Bumper
You don't have to remove the bumper, there are clips in the wheel well. Turn the screws remove the clips pull liner back towards tire and you see what retainer clip is missing. There's a bolt that holds that clip up so you'll need to replace that to if its missing. You can always look at the other side to see how its suppose to be, might be easier if you turn wheel away from side your working on.
Thanks for the tip derpie.
Just replaced my front bumper retainers.
Took me a little longer on the driver side as I surveyed the bumper connectors / clips / bolt and carefully removed the fasteners without breaking anything.
Driver side approx 20-25 minutes. Right side less than 10 minutes.
