ticking / rattling noise
Old 09-14-14, 05:28 PM
anniversar
anniversar's Avatar
Default ticking / rattling noise
Anyone experienced a noise that is evident when the side window is down which seems to coming from underneath the car. It is difficult to describe but it is a ticking / light metallic sound. Possibly coming from the exhaust system area. It is particularly annoying at a drive through window where the sound reflects off the building.
Old 09-14-14, 06:15 PM
is150
is150's Avatar
Going to be hard to diagnose but a couple questions. Is the noise there when the car is cold, warm, or both? Throttle dependent? Only while the car is moving, stopped, or both?
Old 09-14-14, 06:51 PM
GXAlan
GXAlan's Avatar
I had it. The dealer said it was the heat shield flexing with temperature changes.
Old 09-15-14, 11:09 AM
dlbuckls10
dlbuckls10's Avatar
That's all? Problem solved and no repair bill?
Old 09-15-14, 05:46 PM
derpie
derpie's Avatar
When I had that sound it ended up being the water pump, it was covered under warranty thankfully.
Old 09-20-14, 01:41 PM
anniversar
anniversar's Avatar
I hear it when the car is warm and the noise does change with rpm. The higher the rpm, the higher the frequency of the noise. I only hear it when the car is stationary and the window is open.
Old 09-20-14, 03:35 PM
LordBowral
LordBowral's Avatar
1st world problem if you only hear it at a drive through window when stationary ! Lol
It's just the heat shield on the exhaust . All cars do it to various degrees
Old 09-20-14, 03:56 PM
Slvr surfr
Slvr surfr's Avatar
Get your exhaust manifold looked at just to be safe. I just replaced mine because i had those same symptoms. It starts off slightly louder during cold starts but dies down some once warmed as the crack and/or gasket heats up. I would also hear it when driving, especially when close to a wall or divider.
a1rh3adsz
01-07-19 05:23 AM
ghoffner
RC F (2015-present)
12-03-15 12:47 PM
LexusISF23
IS F (2008-2014)
02-19-13 06:01 AM
SGMIS3
07-16-08 01:08 AM
messysc
SC- 1st Gen (1992-2000)
10-18-02 12:34 PM
Quick Reply: ticking / rattling noise
