Any writeup or instructions on dash removal?
Old 08-26-14, 04:56 AM
sparky3
sparky3's Avatar
Default Any writeup or instructions on dash removal?
Just curious if anyone has detailed instructions or a guide on how to completely uninstall / reinstall the dash on a LS460 / 600hl.
Thanks!
Shawn
Old 08-26-14, 12:24 PM
dlbuckls10
dlbuckls10's Avatar
I would let a Lexus dealership deal with that task. It's probably complex and time consuming to uninstall/reinstall the LS dash.
Old 08-26-14, 02:21 PM
Nospinzone
Nospinzone's Avatar
This isn't going to be a big help, but I think somebody posted here that they did that. I don't even think that person started the thread but posted in an existing thread. Maybe someone here remembers more about it, or otherwise try searching but it might not bear fruit.
Old 08-26-14, 03:06 PM
Devh
Devh's Avatar
I have done two dash removals on cars that I parted out. I don't wish that on my worst enemy and it's probably one of the hardest thing to remove on a car. I will do ten clutch replacements before I would remove one dash.
If you lost something in the dash like a wedding ring you can use a borescope to find it.
Old 08-26-14, 05:47 PM
roadfrog
roadfrog's Avatar
He wants to remove the dash in order to replace it.
ALLDATA DIY costs about 20 bucks for a year subscription and covers all aspects of the repair and maintenance of the Lexus LS 460 including the dash.
Old 08-26-14, 05:52 PM
roadfrog
roadfrog's Avatar
I could not attach the pics, but this is the write-up which gives you an idea of whats involved. To be honest, it does not appear to be particularly difficult, but it is definitely time consuming. Lots of precautions too, particularly with all the airbags involved.
INSTRUMENT PANEL: INSTRUMENT PANEL SAFETY PAD: REMOVAL
REMOVAL
1.TABLE OF BOLT, SCREW AND NUT HINT: All bolts, screws and nuts relevant to installing and removing the instrument panel are shown along with their alphabet code in the table below.
2.REMOVE COWL TOP VENTILATOR LOUVER RH See: Starting and Charging\Charging System\Alternator\Service and Repair\Removal
3.DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
(a) Disable the AUTO TILT AWAY function by changing the customize parameter See: Testing and Inspection\Repair Instruction - Customize Parameters.
NOTE: Record the current customize parameter setting (whether the AUTO TILT AWAY function is enabled or disabled) in order to restore the current setting after finishing the operation.
HINT: Performing the above operation causes the AUTO TILT AWAY function to be disabled when the engine switch is turned off.
(b) Turn the engine switch on (IG). Operate the tilt and telescopic switch to fully extend and lower the steering column.
(c) Turn the engine switch off and disconnect the cable from the negative (-) battery terminal.
CAUTION: Wait at least 90 seconds after disconnecting the cable from the negative (-) battery terminal to prevent airbag and seat belt pretensioner activation.
NOTE: After the engine switch is turned off, the HDD navigation system requires approximately 6 minutes to record various types of memory and settings. As a result, after turning the engine switch off, wait 6 minutes or more before disconnecting the cable from the negative (-) battery terminal.
4.REMOVE INSTRUMENT PANEL FINISH PANEL END LH
(a) Using a moulding remover, detach the 8 clips and claw.
(b) Remove the finish panel.
5.REMOVE INSTRUMENT PANEL FINISH PANEL END RH
6.REMOVE SHIFT LEVER **** SUB-ASSEMBLY
(a) Twist the shift lever **** in the direction indicated by the arrow and remove it.
7.REMOVE NO. 3 BOX PANEL
(a) Using a screwdriver, detach the 4 claws.
HINT: Tape the screwdriver tip before use.
(b) Remove the box panel.
8.REMOVE REAR CONSOLE PANEL UPPER
(a) Place protective tape as shown in the illustration.
(b) Move the shift lever to N.
(c) Remove the 2 screws.
(d) Using a screwdriver, detach the 6 clips.
(e) Remove the panel and disconnect the connectors.
9.REMOVE CONSOLE PANEL SUB-ASSEMBLY UPPER
(b) Detach the 2 clips.
(c) Remove the panel and disconnect the connector.
10.REMOVE REAR CONSOLE END PANEL SUB-ASSEMBLY
(a) Using a moulding remover, detach the 5 clips and 2 claws.
(b) Remove the end panel and then disconnect the connector.
11.REMOVE CONSOLE COVER LOWER
(a) Remove the cover.
12.REMOVE CONSOLE BOX ASSEMBLY
(a) Remove the 4 bolts and 2 screws.
(b) Disconnect the connectors.
(c) Detach the 2 claws and remove the console box.
13.REMOVE SWITCH AND VOLUME CASE See: Restraints and Safety Systems\Air Bag Systems\Air Bag\Service and Repair\Steering Pad\Removal
14.REMOVE NO. 2 STEERING WHEEL COVER LOWER See: Restraints and Safety Systems\Air Bag Systems\Air Bag\Service and Repair\Steering Pad\Removal
15.REMOVE STEERING PAD ASSEMBLY See: Restraints and Safety Systems\Air Bag Systems\Air Bag\Service and Repair\Steering Pad\Removal
16.REMOVE STEERING WHEEL ASSEMBLY See: Steering and Suspension\Steering\Steering Column\Service and Repair\Steering Column Assembly (w/ VGRS)\Removal
17.REMOVE STEERING COLUMN COVER (w/o Driver Monitor Camera) See: Steering and Suspension\Steering\Steering Column\Service and Repair\Steering Column Assembly (w/ VGRS)\Removal
18.REMOVE STEERING COLUMN COVER (w/ Driver Monitor Camera) See: Steering and Suspension\Steering\Steering Column\Service and Repair\Steering Column Assembly (w/ VGRS)\Removal
19.REMOVE TURN SIGNAL SWITCH ASSEMBLY WITH SPIRAL CABLE SUB-ASSEMBLY See: Steering and Suspension\Steering\Steering Column\Service and Repair\Steering Column Assembly (w/ VGRS)\Removal
20.REMOVE INSTRUMENT CLUSTER FINISH PANEL SUB-ASSEMBLY
(a) Remove the 2 clips.
(c) Disconnect the connectors and remove the finish panel.
21.REMOVE COMBINATION METER ASSEMBLY
(a) Remove the 4 screws.
(b) Disconnect the connector and remove the combination meter.
22.REMOVE INSTRUMENT SIDE PANEL LH
(a) Using a moulding remover, detach the 6 clips, and remove the side panel.
23.REMOVE NO. 1 INSTRUMENT CLUSTER MOULDING
(a) Using a moulding remover, detach the 2 clips and remove the moulding.
24.REMOVE NO. 1 INSTRUMENT PANEL UNDER COVER SUB-ASSEMBLY
(a) Remove the 2 screws.
(b) Detach the 2 claws.
(c) Disconnect the connectors and clamp, and remove the under cover.
25.REMOVE NO. 1 INSTRUMENT PANEL SAFETY PAD SUB-ASSEMBLY
(a) Using a screwdriver, detach the claw.
(b) Remove the hole cover.
(d) Detach the 5 clips and claw.
(e) Remove the safety pad and then disconnect the connectors.
26.REMOVE DRIVER SIDE KNEE AIRBAG ASSEMBLY See: Restraints and Safety Systems\Air Bag Systems\Air Bag\Service and Repair\Driver Side Knee Airbag Assembly\Removal
27.REMOVE INSTRUMENT SIDE PANEL RH
28.REMOVE NO. 2 INSTRUMENT CLUSTER MOULDING
(a) Using a moulding remover, detach the 5 clips and remove the moulding.
29.REMOVE NO. 2 INSTRUMENT PANEL UNDER COVER SUB-ASSEMBLY
(a) Detach the 4 claws.
(b) Remove the under cover and then disconnect the connector.
30.REMOVE INSTRUMENT PANEL LOWER See: Restraints and Safety Systems\Air Bag Systems\Air Bag\Service and Repair\Front Passenger Side Knee Airbag Assembly\Removal
31.REMOVE FRONT PASSENGER SIDE KNEE AIRBAG ASSEMBLY See: Restraints and Safety Systems\Air Bag Systems\Air Bag\Service and Repair\Front Passenger Side Knee Airbag Assembly\Removal
32.REMOVE GLOVE COMPARTMENT DOOR ASSEMBLY
(a) Remove the 5 screws.
(b) Disconnect the connector and clamp, and remove the compartment door.
33.REMOVE RADIO RECEIVER ASSEMBLY WITH BRACKET See: Accessories and Optional Equipment\Radio/Stereo\Service and Repair\Radio Receiver\Removal
34.REMOVE INTEGRATION CONTROL AND PANEL ASSEMBLY WITH BRACKET (w/o Navigation System) See: Heating and Air Conditioning\Control Assembly\Service and Repair\Removal
35.REMOVE MULTI-DISPLAY ASSEMBLY WITH BRACKET (for DVD) See: Accessories and Optional Equipment\Navigation Display\Service and Repair\Removal
36.REMOVE DISPLAY AND NAVIGATION ASSEMBLY WITH BRACKET (for HDD) See: Accessories and Optional Equipment\Navigation System\Service and Repair\Display and Navigation Assembly\Removal
37.REMOVE NO. 1 INSTRUMENT PANEL REGISTER ASSEMBLY
(b) Using a moulding remover, detach the upper 2 claws.
(c) Detach the lower 2 claws.
(d) Disconnect the connector and remove the register.
38.REMOVE NO. 2 INSTRUMENT PANEL REGISTER ASSEMBLY
39.REMOVE FRONT PILLAR GARNISH LH See: Body and Frame\Interior Moulding / Trim\Headliner\Service and Repair\Roof Headlining (for Standard Body)\Removal
40.REMOVE FRONT PILLAR GARNISH RH See: Body and Frame\Interior Moulding / Trim\Headliner\Service and Repair\Roof Headlining (for Standard Body)\Removal
41.REMOVE NO. 1 INSTRUMENT PANEL SPEAKER PANEL SUB-ASSEMBLY See: Accessories and Optional Equipment\Speaker\Service and Repair\Instrument Panel Speaker\Removal
42.REMOVE FRONT NO. 2 SPEAKER ASSEMBLY (for LH Side) See: Accessories and Optional Equipment\Speaker\Service and Repair\Instrument Panel Speaker\Removal
43.REMOVE NO. 2 INSTRUMENT PANEL SPEAKER PANEL SUB-ASSEMBLY See: Accessories and Optional Equipment\Speaker\Service and Repair\Instrument Panel Speaker\Removal
44.REMOVE FRONT NO. 2 SPEAKER ASSEMBLY (for RH Side) See: Accessories and Optional Equipment\Speaker\Service and Repair\Instrument Panel Speaker\Removal
45.REMOVE NO. 1 SPEAKER HOLE COVER See: Accessories and Optional Equipment\Speaker\Service and Repair\Instrument Panel Speaker\Removal
46.REMOVE FRONT NO. 3 SPEAKER ASSEMBLY See: Accessories and Optional Equipment\Speaker\Service and Repair\Instrument Panel Speaker\Removal
47.REMOVE INSTRUMENT PANEL SAFETY PAD SUB-ASSEMBLY
(a) Disconnect the connectors and clamps.
(b) Remove the 2 passenger airbag bolts.
(c) Remove the 5 bolts and nut.
(d) Detach the 5 claws and remove the safety pad.
48.REMOVE NO. 3 INSTRUMENT PANEL STAY
(a) Detach the 5 claws and remove the 5 stays.
Account | Vehicle | Help | Contact | AutoZone Community | Exit
Old 08-26-14, 07:29 PM
sparky3
sparky3's Avatar
Thanks a lot Roadfrog!
Old 08-26-14, 08:35 PM
roadfrog
roadfrog's Avatar
My pleasure....that's what it's all about here at CL.
I wish I could help with the photos, but it's all here at AllData DIY:
http://www.alldatadiy.com/
Old 08-28-14, 02:09 PM
tnbigdawg
tnbigdawg's Avatar
Thanks roadfrog! This is on my todo list some day....to fix the dash rattles not covered by my aftermarket warranty =/
mk4umha
12-02-14 06:29 AM
Jjman79
04-06-14 12:45 PM
Top Hat
10-02-08 07:48 AM
Quick Reply: Any writeup or instructions on dash removal?
