Possible to wire LOC, ML subwoofer and aftermarket subwoofer together
Just wondering if this is possible. My ML sub isn't blown, but want to add a little more bass. Has anyone wired the LOC in line with the ML sub still connected and an aftermaket sub
ML sub>LOC>aftermarket amp>aftermarket sub
thanks!
thanks!
that's how mine is wired in. I didn't see a sense in removing or disconnecting the factory sub. mine has been like that for about 3 months and I haven't had any issues. I listen normally around 25 but will turn it up to 40-45 on a good song so it's been played loud for short times. never skipped a beat (no pun intended)
I tapped into the wires just before they go into the subwoofer. Did it about 4 or 5 months ago. I installed an in line volume control too. Do a search on here. There are several threads regarding this subject.
is the cig lighter always on in center console, I remember tapping the wire in prior Lexus’s I’ve owned....
It looks like the connector has 4 wires and that two wires go to each side of the sub, does that mean that it’s a single channel with dual voice coil? I’m going to wire in an amp and aftermarket sub and want to take this factory sub signal as my new amp input. I want to wire these into a set of rcas. Which is positive and negative? Thank you.
Mbodall
07-02-18 11:47 AM
