Hybrid system jumpstarting itself when 12V battery is depleted ? - Club Lexus Forums
Thread Tools Search this Thread
Old 07-20-14, 06:52 AM   #1
Vansibel
Vansibel's Avatar
Default Hybrid system jumpstarting itself when 12V battery is depleted ?
I just read this thread: http://www.clublexus.com/forums/ls46...ce-or-not.html
I recalled when purchasing my previous ls600hl someone at the dealership told me that the car was able to give power to it's 12v battery in the case that it was depleted, making it virtually impossible to fail to start the car because of low remaining power on the 12V battery. On the thread I quoted it doesn't seem clear as to which of the 12v battery or the hybrid system start the car. From what I read the master technician in that thread said that the 12V wasn't used to start the car but only to power accessories (and maybe act as a relay to start the hybrid system ?). In the thread I quoted, CJITTY described a behavior much alike the one I described in that thread: http://www.clublexus.com/forums/ls46...ft-on-acc.html
My new ls600 is a 2008 and I doubt that the 12v ever been changed. Just recently if I put the car on ACC for more that a minute the car go haywire as described in the thread I created. I'm guessing that the battery need to be replaced. But one interesting thing is that I NEVER failed to start the car, and this happened to me several times. When the car won't start, I just wait a few moment when left in ACC and press the brake for like 10 sec so the green light lit on the start button, and press down (keep pressed) the start button for 5 sec, then release (Sometime I open then close the door before waiting 10 sec then restart the procedure). On the third time the car usually start. So that seems to confirm that the hybrid system might actually give some juice to the 12V battery, or maybe there is a kind of failsafe mechanism that bypass the 12V battery so the hybrid system could start the car ? Would be interesting to know on how exactly the system work when starting the car.
Vansibel is offline   Reply With Quote
Old 07-21-14, 11:25 AM   #2
CJITTY
CJITTY's Avatar
Interesting indeed. I have a 12v jump start box I keep with me for emergencies in general and on the rare occassion I am working on the car without it running and kill the 12v battery, I just hook up the box to the battery in the trunk and it cranks up right away. Lexus tells me they have this problem often when doing alighnments and things like that on hybrids. My battery tested great, no replacement needed even after all of that. But your workaround info is interesting to say the least
CJITTY is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
2008 GS350 AWD Jerking/Hesitation at Low Speed oxus GS - 3rd Gen (2006-2011) 91 11-19-16 10:28 AM
***LS460 | LS460L | LS600hL FAQ (Frequently Asked Questions) DIY/Info Thread*** Tee LS - 4th Gen (2007-present) 0 08-30-13 09:04 PM
LS430 Upgrade: LS600 Build Pix mewhee LS - 3rd Gen (2001-2006) 1 09-20-10 11:50 PM
Motor Trend passes on the the LS 600h L irieblue LS - 4th Gen (2007-present) 29 02-19-08 05:30 PM
★ LS460 | LS460L | LS600hL FAQ (Frequently Asked Questions) and DIY Thread ★ FAQ & DIY LS - 4th Gen (2007-present) 0 04-13-01 05:00 AM
Tags
battery 12v, depleted, hybrid, ls600hl, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
