Using Parking Brake Auto Feature - Club Lexus Forums
Thread Tools Search this Thread
Old 07-15-14, 06:07 PM   #1
DJWLDW
DJWLDW's Avatar
Default Using Parking Brake Auto Feature
I have a question about how many use the auto parking brake function. I did a search and know what it is and how it works but I did not find anything indicating how may folks use it. I must admit that I rarely if ever use my parking/emergency brake unless I find myself being forced to park on a fairly steep incline. My inclination is not to use it. My concerns are that it might not release when you moved the shift lever out of park. Or in the winter and the parking brake became frozen thus not releasing when you wanted to leave. Thoughts would be appreciated. As a side not I believe that this is the last button/switch I needed to figure out just what it did. This is a very thick book.
Dennis
DJWLDW is offline   Reply With Quote
Old 07-15-14, 06:47 PM   #2
Nospinzone
Nospinzone's Avatar
I never use it unless I'm parking on a hill.
BTW, shifting out of Park will not release it, you have to pull the tab towards you (unless they changed it from '07).
Nospinzone is offline   Reply With Quote
Old 07-15-14, 07:01 PM   #3
slimjimtel
The 2010 has the auto parking brake. Mine is ON auto ALL the time. I don't see any issues. For years people have been using pull parking brakes for manual drive cars. NO difference here...set it and forget it!
slimjimtel is offline   Reply With Quote
Old 07-15-14, 07:41 PM   #4
DJWLDW
DJWLDW's Avatar
I also have the auto feature. Slimjimtel, I see you live in NC ever had a problem with it freezing in the winter months?
Dennis
Old 07-15-14, 07:43 PM   #5
mcomer
mcomer's Avatar
As you may have discovered, the Auto Parking Brake uses an electric motor to engage and release the mechanical parking brake cable. Traditional PB would need your muscle power to lift a lever or press a
pedal. Pulling or pushing the PB toggle just does the work for you. The Auto function removes the additional step and ties the brake application to the shift lever, Park engages the PB, all other ranges releases it.
Your concern about not releasing is valid, if the PB has not been used regularly or recently it may very well
draw tight but not release. My real objection to the automation is that the most effective use of the PB is to
deliberately apply it while the main brakes are held and before the transmission parking pawl is engaged. When you release the main brakes the weight of the car is held by the friction of the brakes and not by the
drivetrain. Ever try getting a car parked on a moderate to steep hill out of Park? Worst case scenario is that
you must push the car uphill slightly to allow the disengagement of the transmission lock.
My opinion is that you can use the PB Auto button to apply the brakes regularly, but turn it off and use the
toggle to apply the brakes before shifting into Park on hills. Be sure to shift out of Park before releasing the PB (and do remember to release it, you may have become spoiled by not needing to remember this!)
mcomer is offline   Reply With Quote
Old 07-15-14, 07:48 PM   #6
CJITTY
CJITTY's Avatar
My 2007 460 and 2008 600hL both have the Auto Parking Brake. I can't recall a time it has been off. Mine is on all the time.
CJITTY is offline   Reply With Quote
Old 07-15-14, 07:58 PM   #7
Tee
Tee's Avatar
Quote:
Ditto replace the 600hl with 460L, I never turned it off on either car.
Tee is offline   Reply With Quote
Old 07-16-14, 01:30 AM   #8
LordBowral
LordBowral's Avatar
Mine is always on with zero problems .it fully automatic . Its not good leaving your car in park without the park brake on, puts a lot of strain on the transmission .
LordBowral is offline   Reply With Quote
Old 07-16-14, 03:53 AM   #9
slimjimtel
Quote:
Dennis
It doesn't get cold enough in NC to really freeze anything.
I would set it to Auto and never look back
Old 07-16-14, 05:08 AM   #10
LordBowral
LordBowral's Avatar
You can rest assured Lexus tested it freezing conditions far worse than anything in the real world . They have massive deep freeze chambers they test cars in exhaustively
Old 07-16-14, 06:27 AM   #11
PeteinPA
I set it and forget it on my '08.
PeteinPA is offline   Reply With Quote
Old 07-16-14, 06:58 AM   #12
hjones4841
hjones4841's Avatar
Same here on my 2011 - auto all the time.
hjones4841 is offline   Reply With Quote
Old 07-16-14, 07:17 AM   #13
DJWLDW
DJWLDW's Avatar
Ok guys going with the big AUTO. Thanks for the input
Dennis
Old 07-17-14, 02:55 PM   #14
RandyV
RandyV's Avatar
My 2007 LS460 has the auto part feature - it is always left on.
RandyV is offline   Reply With Quote
Old 07-17-14, 03:01 PM   #15
SBlexus
SBlexus's Avatar
I keep mines on and it's all auto, once u shift out of park the brake disengage.
SBlexus is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Parking Brake not working 05Flagship LS - 3rd Gen (2001-2006) 2 08-08-15 11:03 AM
Head Rest Trick DJWLDW LS - 4th Gen (2007-present) 13 08-13-14 08:00 PM
parking brake got stuck rx330 2007 binhnv RX - 2nd Gen (2004-2009) 3 03-10-13 04:42 PM
99 LS: just changed rear brakes, now something is rubbing MadMax96 LS - 1st and 2nd Gen (1990-2000) 5 09-09-09 11:33 AM
Parking Brake: Please tell me there is a dash release? winsalem GS - 3rd Gen (2006-2011) 5 03-14-05 01:40 PM
Tags
07, 250, applying, automatically, brakes, lexus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
