LS remote start install DIY
#167
Restart the vehicle normally with the push to start button, and then try hitting the remote 4 or 5 times instead of 3. I either can't count well or I usually hit it at least 4 times to make sure it starts up. Mine did the same thing when I first installed it, and I think the restart and shut off helped. IIRC
#168
Did you follow the programming of it word for word after installation? Should be on page 11 and 12 in the manual. If you have a solid green then you should be good.
Tried what u suggested and still nothing...
#169
My turn signals flash when I press the lock button as they always have. Double check your wiring. If you have the green light then you know it has power, so thats a plus. Check on the programming and make sure the battery is good in the FOB.
#170
My bad, I meant the lights on the module don't come on.. parking lights are good. Had it flashed by Toby so I'm hoping that's good.. I'll check the other wires connected with the t-taps, they look good but maybe they aren't getting a solid connection
#171
I verified all wires are connected secured and to the correct wire. Not sure why it's not working, is there any difference if i have the 4 x 10 instead of the DBALL2.
#172
Can someone take a look at the diagram for the 4x10 and let me know exactly which wires need to be connected? Seems like it's a little different from the DBALL
#173
Ok... for those that dont know t taps are NOT a solid or recommend method to wiring solution. .... if your not goin to solder it.. use a military splice.. (strip the wires sheath back split the wire like the eye of a needle then thread it with your new wire. Wrap the new wire around the eye tightening it together as u wind. Then wrap it with 3m E tape. THEN use a wire tie on the 2 wire side of the connection to make sure it cant pull loose) fyi most of these wires transfer DATA to the cpu(billions of codes per sec). Not just simple voltage.. so a solid connection is a MUST.. a flimsy t tap connection wont support data properly..
If your local installer is still using t taps... do yourself a favor GO SOMEWHERE ELSE!!!!!
this has been a public service announcement.... i now return u to your thread!! #ttapsin2015isajoke
#174
http://cdncontent2.idatalink.com/cor...EM-AL(RS)-TL3-[FLCAN]-EN_20150410.pdf
FYI the Flashlogic FLCAN RS-TL3 does work on my 2011 LS460L to remote start with lexus keyfob 3x lock.
You may need to copy the whole address and paste it into your address bar. I don't know why it cut off the last part.
#175
#176
I'm not certain what you mean by "take-over issue". I'm new here and on vacation, the internet is too slow for me to have the patience to search and figure it out. I think you want to know if the car turns off when I open the door. It does in fact turn off automatically when the door opens after a remote start.
#177
#178
For $69 and 1hr of labor, worth looking into since I live in MN. A dealership charged me $600 to put in a remote starter in my GX460 where I could use my key fob to start the car. Is this the same device/method the dealership is using when installing a remote starter?
#179
No its not the same device. Its alot better... plus if u use the dball2 it leaves the option open too add smart start (or smart start gps). To remote start the car from anywhere via your smartphone...
#180
So there's 12 pages worth of content to go through... But at one point it looks like a firmware update to the dball screwed up the three lock button start.
Can you outline the new procedure/products we should buy (for us people who are just getting into this) to get the ball rolling on remote start? Winter is coming soon and I don't feel like paying Lexus 600 bucks or other install shops 300 bucks if I can get it for less than 100 bucks.
