LS460 Carista App Review - Ability To Change Lexus Personalized Settings
Old 02-24-15, 07:18 AM
  #91
roadfrog
roadfrog's Avatar
Originally Posted by LS2k
On the '07 isthe seat/steering wheel retract available and can it be enabled through carista?
I just double-checked this on my app (I have an 08), and this is NOT available. Neither the seat, nor the steering wheel.
Old 02-24-15, 07:58 AM
  #92
LS2k
LS2k's Avatar
Thanks, can the seat retract be enabled w/o carista/dealer?
Old 02-24-15, 08:09 AM
  #93
Carista
Former Sponsor
Carista's Avatar
If you have a nav, it should be one of the settings available through there (again, only if the car supports it, which it's sounding like it may not).
Old 02-24-15, 08:32 PM
  #94
aaauae
aaauae's Avatar
any way to Disable the speed Limiter using Carista ? its electronically limited so there should be a walk around ?
Old 02-25-15, 06:31 AM
  #95
tbilisi79
tbilisi79's Avatar
Need to go faster than 130? I don't believe carista can change the limiter. I didn't see it at least.
I was very happy with the app.
Turned off DRL
Turned off the rear shade from going down in reverse.
Turned off seat belt buzzers, even though I always use seat belts.
Increased sensitivity of auto headlights.
Activated car unlock when put to park.
Changed setting for trunk to open on one click of the remote button instead of 2
Only thing i couldn't do is disable auto steering wheel away.
Old 02-25-15, 08:52 AM
  #96
Carista
Former Sponsor
Carista's Avatar
No, we don't have that setting and I don't think it's configurable at all, even by a dealer.
Turned off DRL
Thanks, we're glad you're happy with it Btw, the steering wheel auto-away is configurable, but it's a weird type of setting (technically different from all the others), so we haven't implemented it yet. It's in the plans though.
Old 02-25-15, 08:07 PM
  #97
aaauae
aaauae's Avatar
Turned off DRL
Yes 130 is very less for this car we got long highways without many Speed Cameras .. this car has a potential of around 300Kmh ... with right tires and everything its easy to hit 300kmh . i really wanna get rid of Speed limiter .. any idea Ecu tuning will help ?
Old 05-05-16, 10:52 AM
  #98
jasone36
jasone36's Avatar
Resurrecting an old thread here...
...is there much use for the Carista App in the 2013+ models?
It seems many settings can be changed via the infotainment system directly.
Does anyone use Carista in a 2013+ LS?
Thank you in advance.
Old 05-05-16, 01:41 PM
  #99
Dr. Jekyll
Dr. Jekyll's Avatar
No there is not. We can adjust nearly everything on a 13+ LS the app can do.
Old 05-05-16, 01:51 PM
  #100
comotiger
comotiger's Avatar
Hi Dr. J, can we really adjust everything ourselves? The manual shows that many vehicle settings can only be changed by the dealer. For example, quoting an earlier post,
Need to go faster than 130? I don't believe carista can change the limiter. I didn't see it at least. I was very happy with the app.
Turned off DRL
Can we really change these functions?
Best wishes,
AC
Old 05-05-16, 02:05 PM
  #101
Dr. Jekyll
Dr. Jekyll's Avatar
Best wishes,
AC
Like I said nearly all, some of those you can some of those you cannot, consult your owners manual, it's in there. I set my car up to my preferences.
Old 05-22-17, 06:25 AM
  #102
Streetcar1
Streetcar1's Avatar
Will this app adjust the airride to lower it an inch or so ?
Old 05-22-17, 06:58 AM
  #103
teedub21
teedub21's Avatar
no, I won't. Carista said they'd look into it but that was a while ago.
Streetcar1 (05-22-17)
Old 05-22-17, 11:43 AM
  #104
Streetcar1
Streetcar1's Avatar
alpreciate the response , yea might look into the tech stream .
Old 05-22-17, 06:54 PM
  #105
213374U
213374U's Avatar
Still haven't figured out how to save height adjustments with techstream, but then again I haven't played with it much over the past couple months. Let me know if you figure it out.
Streetcar1 (05-23-17)
Quick Reply: LS460 Carista App Review - Ability To Change Lexus Personalized Settings
