Philips LED/DRL
Old 02-22-14, 01:57 PM
PeteinPA
PeteinPA's Avatar
Default Philips LED/DRL
Picked these up a few weeks ago. Easy install. I like the color temp as they are closer to the rest of the lights, Nike lights a 28smd LED's, Low beams are stock, fogs are 4300K HID.
Sorry for the crappy cell phone pics.
Attached Thumbnails Philips LED/DRL-photo-1.jpg   Philips LED/DRL-photo-3.jpg   Philips LED/DRL-photo-4.jpg   Philips LED/DRL-photo-5.jpg
Old 02-22-14, 02:59 PM
shrikelex
shrikelex's Avatar
Looks good, What was the install process like, take long? did you have to remove the entire headlight and what was the cost, thanks
Old 02-22-14, 03:25 PM
PeteinPA
PeteinPA's Avatar
Sure,
Install was simple. It comes with a control unit that is prewired for the battery, just loosen the nuts on the terminals, there a connectors on the end of the wires, slip them behind the nut and tighten.
As for the lights, I used the 3m double sided tape, cut a trip the size of the light and placed on top, then just pressed into place. Can't really use the brackets that come with the kit . No where to put in the brackets as far as I could tell. The 3m tape works really well.
Each light comes hardwired at the light and a connector that connects to the control unit.
There is a third wire that the recommend you tie into the parking lights (they provide the connector), will make the DRL's dim when you put on the parking/headlights. I chose not to use it.
I removed the grill to make it easier to get to the wires at the bottom of the bumper. You can find post on how to remove the grill. You also have to remove all the engine shrouds.
Took me about 30 minutes give or take a few minutes.
Old 02-22-14, 05:48 PM
jiceoo
jiceoo's Avatar
Nice, job well done.
Old 02-22-14, 08:21 PM
roadfrog
roadfrog's Avatar
Looks good. Nice if we could get a close up!
I have a similar setup arriving early next week.....same as CJitty's. 9 LED strip.
Old 02-23-14, 04:57 AM
PeteinPA
PeteinPA's Avatar
Chris, I will try to get a close up today and post it. I had the same as CJ and Tee, they look good but the color temp was a little too high for me. I think they are like 6000-7000 which is trending toward blue.
I wanted to stay closer to white so these worked better for me. They are however a little pricey, I think I paid close to $80 on Ebay for the kit.
Old 02-23-14, 06:13 AM
PeteinPA
PeteinPA's Avatar
Default Close Up Pics
Here are a couple of close of pics. I wanted to keep all the lights close to white as I think the white looks more OEM IMO.
Attached Thumbnails Philips LED/DRL-photo-1.jpg   Philips LED/DRL-photo-2.jpg   Philips LED/DRL-photo-3.jpg
Old 02-23-14, 06:28 AM
roadfrog
roadfrog's Avatar
Looks great Pal. Well done! Thanks for the pics.
Old 02-23-14, 06:30 AM
PeteinPA
PeteinPA's Avatar
Thanks Chris.
Old 02-23-14, 06:35 AM
roadfrog
roadfrog's Avatar
You just have to black out that grill now Pete! LOL
Old 02-23-14, 07:41 AM
PeteinPA
PeteinPA's Avatar
Don't think I haven't considered it. I like what you and a few other CL members did with the Plasti dip.
My first priority is to get a set of rims. I have snows on the stock rims now (can't wait to take them off). Just need to decide if I am going with a set of 19" OEM's or 20" aftermarkets.
Old 02-23-14, 11:17 AM
CJITTY
CJITTY's Avatar
Pics and vids are deceiving. .our were pure white in person
Old 02-23-14, 11:53 AM
PeteinPA
PeteinPA's Avatar
CJ, I had purchased and installed a set that looked very similar to those you had from another CL member. However it is possible they were different, when I had them on they looked like a higher temp, I think they even said 6000-7000. I liked them but the Phillips just appear closer in color to the stock headlights and my HID fogs.
Old 02-23-14, 12:21 PM
roadfrog
roadfrog's Avatar
Oh well YEAH! Definitely wheels first... and obviously I like 20's. They're a good compromise for me as I still wanted significant ride comfort.
I decided to take my snows off a couple of weeks ago as we get so little (if any), snow here in this part of Canada, especially at this time of year. Guess what it's doing outside right now? Argghhhh!!! LOL. Oh well, supposed to get up around 55-60 degrees by Tuesday.
BailsVT
08-03-14 03:37 PM
class87
07-26-12 12:36 PM
stasis3131
04-28-12 01:06 PM
smilepak
05-17-11 11:41 PM
K3vL3x
11-19-10 11:38 PM
Quick Reply: Philips LED/DRL
