LS460 abs vsc system problem
Old 02-19-14, 07:24 AM
mundher44
mundher44's Avatar
Default LS460 abs vsc system problem
Hi everybody sorry to disturb you..
I have a problem in my lexus ls460
Yesterday I was driving (its was raining) and suddenly 5 lights appeared in the dash board and a messages says : check abs vsc brake system.. stop the car in a safe place and contact a dealer .. anybody knows whats the problem .. many thanks and I will attach a picture after a while
Old 02-19-14, 07:54 AM
mundher44
mundher44's Avatar
Old 02-19-14, 08:00 AM
mundher44
mundher44's Avatar
any help will be appreciated..
Old 02-19-14, 08:54 AM
AznRacer
AznRacer's Avatar
This happen to me yesterday morning too while taking the kids to school. I took it straight the lexus dealership for them to see what's the problem. After a day they finally called me saying that the abs actuator is bad and it need to be replace. Good thing I have third party extended warranty hopefully they'll cover the repair. Btw I have 09 swb with 91k
Old 02-19-14, 09:12 AM
jmcraney
jmcraney's Avatar
This may be an indication of a defective battery. You should have the battery tested by a battery dealer.
Old 02-19-14, 11:09 AM
Nospinzone
Nospinzone's Avatar
I agree, first thing I would check is the battery.
Old 02-19-14, 11:35 AM
Aristo300
Aristo300's Avatar
My 07 with 67k miles did this on and off for about 2 weeks right after purchasing. It was reset by the dealer twice and has since gone away. I suspect it was a battery issue and that now the battery has charged itself back to normal.
Old 02-19-14, 02:28 PM
Tdvlexo
Tdvlexo's Avatar
Mine warning lights came on like yours last fall and I had to replace my brake booster and my brake actuator. If your warranty on your car is expired, get ready to fork out some money.
Old 02-20-14, 03:00 AM
cuscon
cuscon's Avatar
Yes I agree check the battery
Old 02-20-14, 05:58 AM
mundher44
mundher44's Avatar
thanks for your replays
I am confused how its related to the battery???
I had a dead battery more than 3 times but these lights never came on until now and the battery is working fine
Anyway I will take it to a battery dealer to check it out
Old 02-20-14, 06:03 AM
mundher44
mundher44's Avatar
Thanks for your replays..
yes I heard it will cost 2600$!!!
But I hope its a faulty abs sensor not brake actuator/booster
Old 02-20-14, 07:00 AM
roadfrog
roadfrog's Avatar
FWIW....Ebay has the actuators for about 800 dollars. The ABS/VSC modules are about 200 dollars.
Old 02-20-14, 03:41 PM
AznRacer
AznRacer's Avatar
Just got the car back. My actuator was leaking a bit but nothing major so the extended warranty refuse to pay for the repair. I wasn't going to put out a few thousand myself so my service adviser and technician said it's okay to drive. If the lights comes back on again the warranty company will have no choice but to do the repair it then.
Old 02-20-14, 05:21 PM
Tdvlexo
Tdvlexo's Avatar
I am certain that when the dealer replace the actuator , they replace it with the LS600 actuator. I don't know what the difference between the two but the LS600 doesn't have that problem, that's what they told me when I got mine replaced.
Old 02-20-14, 05:53 PM
1Putt
1Putt's Avatar
+1, its been posted before that the dealer uses the ls600 actuator as a replacement. The ls460 part# is now the same as the ls600 part
Quick Reply: LS460 abs vsc system problem
