Garage door opener distance
Old 02-05-14, 02:54 PM
RR601
RR601's Avatar
Default Garage door opener distance
Have a Chamberlin garage door opener with the rolling codes. The remote that came with it will operate from 60 to 80 ft. away.
The lexus opener on my 2011 LS has to be very close to the garage door. About 15 ft away.
Is this normal?
Thanks
Old 02-05-14, 03:01 PM
Joeb427
Joeb427's Avatar
Liftmaster here and the GS works up to around 100ft.
Old 02-05-14, 03:30 PM
gs400jon
gs400jon's Avatar
Lift-Master, 100 feet plus
Old 02-05-14, 06:24 PM
jmcraney
Forum Moderator
jmcraney's Avatar
Is this normal?
Thanks
Please tell us the model # for your garage door opener. Or more specifically, if you know, does it use the "Security +2.0" or newer rolling code system?
Old 02-05-14, 06:26 PM
tyrenfroe
tyrenfroe's Avatar
Chamberlain/LiftMaster 2007 LS 100-200ft never misses.
Old 02-05-14, 07:18 PM
RR601
RR601's Avatar
Its a Chamberlain Wisper Drive HD900D with battery backup. Bought in 2008.
Manual does say Security+ but not 2.0 anywhere.
Old 02-05-14, 07:42 PM
jmcraney
Forum Moderator
jmcraney's Avatar
Good, there was a problem with older HomeLink operating the newer openers but you don't seem to have that problem.
Your car's HomeLink should work out to a couple hundred feet or more. It is unlikely that there is a problem with your car. The first thing that you should try is erasing the car's HomeLink and erasing the opener's memory and re-syncing them. Be sure to use one of the remote openers that came with the garage opener to set up the garage opener initially and test that it has good range. Then use the same opener to set up the car's HomeLink. The car does not learn the code from the remote but does learn the frequency and format. After you train the car's HomeLink then you will have to sync the opener with the car's HomeLink.
HomeLink has an Internet site that explains how to do all that and they have a support group that is very good at helping resolve issues.
You can find them here: http://www.homelink.com/home/welcome
Old 02-05-14, 08:51 PM
CJITTY
CJITTY's Avatar
Chamberlain here also and all I know is I hit my button about 3 houses away and its open when I hit my driveway
Old 02-06-14, 12:37 AM
RR601
RR601's Avatar
Pretty sure I found the problem. Just realized this started when I replaced the Garage door opener light bulbs with the new LED bulbs. I knew neon light could could a problem. But reading on the web so can LEDs.
Only had the car about 10 days so just getting used to it.
Will try the reprograming. But don't think that is the problem. The lexus remote works just has limited range and I have to hold the button down for a few seconds for it to work.
Its a shame because the LEDs were brighter, used only 9 watts and were rated to last 10 years.
Old 02-06-14, 02:14 AM
chpten8
chpten8's Avatar
Relocate the antenna on the garage door opener away and lower from the lights to cease interference.
Old 02-06-14, 03:24 AM
hjones4841
hjones4841's Avatar
I was about to post that. The antenna should hang vertically and straight.
Old 02-06-14, 07:13 AM
RR601
RR601's Avatar
Definitely was the LED light bulbs. And this was the brand name one.
Actually with the lights on the Lexus or Chamberlin remotes would not work before or after reprogramming with the garage opener lights on.
I put back in the old style standard bubs and Lexus and other remotes works at least 75 ft out. . Did not try further.
On the first post I thought the Chamberlin remotes were still working because by the time I tried them the garage opener lights had turned off. Same thing, by the time I had pulled the Lexus back in the driveway and close to the door to retry, the lights had just turned off.
So everything works great. Just don’t use LED bulbs in a garage opener...
Old 02-06-14, 07:16 AM
RR601
RR601's Avatar
Antenna was already straight down. Don't think I can relocate the antenna or make it longer. It would still pick up the signal in the LED bulbs.
Also these were the CREE brand LEDs in case anyone interested.
Old 02-06-14, 07:17 AM
Joeb427
Joeb427's Avatar
I have LED bulbs and have at least a 100ft range.Never really tried anything longer.
Old 02-06-14, 07:54 AM
RR601
RR601's Avatar
Do you happen to know which brand? I would like to try them if you don't mind checking.
I am sure that my LED bulbs were my problem. Could it be different with different openers or brand bulbs?
Quick Reply: Garage door opener distance
