07 LS 460 Trunk issue
Old 01-19-14, 10:39 AM
Z0SICK
Z0SICK's Avatar
Default 07 LS 460 Trunk issue
Hello all,
I read through some previous post and I seem to have a similar problem....
*Trunk is not equipped with power trunk opener and closer.
*Valet switch in glove box has been checked
The beep sounds when using the trunk release on fob but trunk does not try to open...
The beep sounds when using the button under trunk lid handle but trunk does not try to open...
The trunk release button under dashboard seems unresponsive...
I used the physical key in the trunk and hear it unlock but the trunk will not open.. seems jammed or something like the auto-close (you manually shut the trunk lid but the last inch or so it locks it down automatically) feature will not disengage...
Anyone experienced this occurence?
Horror stories?
Remedies?
Thanks ClubLexus.
Old 01-19-14, 11:01 AM
Z0SICK
Z0SICK's Avatar
FOR ANYONE having a similar issue - disconnecting the positive terminal of the battery seems to do the trick!
not even reaching the trunk release inside the trunk seems to open it.... however, it seems the problem lies within the auto close feature in the models malfunctioning. Good luck to all!
Old 01-19-14, 12:44 PM
Nospinzone
Nospinzone's Avatar
Hey Z0SICK, glad you discovered it by yourself, but the fix is here in the sticky at the top of this forum -
https://www.clublexus.com/forums/ls4...fo-thread.html
nmumford
03-10-19 04:27 PM
sxbaker
06-05-17 12:21 PM
peasodos
02-15-17 08:16 AM
rziez
09-09-13 05:14 PM
Celsius
07-12-09 07:34 AM
Quick Reply: 07 LS 460 Trunk issue
