07 LS460 Upper & Lower control arm bushings replacement - Page 5 - Club Lexus Forums
Thread Tools Search this Thread
Old 06-09-14, 11:47 PM   #61
randomwalk
Awesome work. How is the ride now with brand new bushings?
randomwalk is offline   Reply With Quote
Old 06-10-14, 05:56 AM   #62
robert1408
The smooth road ride did not change much, that was good already. The big difference is over sharp edged stuff like small potholes and manhole covers. It's much less harsh now. The only bushing that was visibly torn and disintegrating was lower right forward one. I think this is the one that was telegraphing a fair amount of sharp bump harshness into the car.
robert1408 is offline   Reply With Quote
Old 06-10-14, 08:42 AM   #63
sktn77a
sktn77a's Avatar
Robert:
Was all this on your dime or did you have an extended warranty that covered it?
sktn77a is offline   Reply With Quote
Old 06-10-14, 09:49 AM   #64
robert1408
I paid for all this . My car is well out of warranty. I bought this car in a pass-through transaction from my mother around Christmas of 2013. The factory warranty was timed out in June, 2013. I knew when I bought it that it would need this and a few other things so I'm budgeted for it.
Old 06-19-14, 11:48 AM   #65
mubarak888
mubarak888's Avatar
Default 8 rms
If I want buy how I will contoct with you
mubarak888 is offline   Reply With Quote
Old 06-25-14, 11:08 AM   #66
mubarak888
mubarak888's Avatar
Default helllo
Hello
Can I order the 4 front upper control arm and 4 lower control arm bushings
Can you send me details in this email address
Mubarak48048@gmail.com
Old 09-17-14, 01:22 PM   #67
wayman28
Quote:
Originally Posted by Vvman View Post
The Armstrong PU bushes installed on the upper control arms started to make some donkey bray 'eek nork' sound driving over road humps.
I have used grease on them liberally prior to installation but I guess this started to wear off recently. The PU bushes were also kind of 'loose' sitting in their control arms such that they 'rotate' a bit too much when the wheels are turned.
Not feeling comfortable and slightly annoyed by the noise, I'd changed them out.
Got them installed on the very day I received them in the mail and the car feels even tighter at the front when going around bends - that was my first impression. It has been almost a week now, no problem whatsoever, I guess I am done with this project.
Vvman, now that you've had your polyurethane bushings in for a few months is the ride much stiffer and is there any squeaking still going on? There's a lot of debate in the car world over polyurethane bushings versus rubber when trying to balance the durability of poly versus stiffer rides and squeaking noise. Thanks.
wayman28 is offline   Reply With Quote
Old 09-17-14, 05:29 PM   #68
Lavrishevo
Lavrishevo's Avatar
If I may comment, the general consensus is to stay with oem urethane style bushings. Not polyurethane. The has been documented very well in the 430 and 400 forums. Many who installed the poly's comment on how it ruins the ride and consistently squeaks. This is particularly true for the front.
Lavrishevo is offline   Reply With Quote
Old 10-18-14, 08:04 PM   #69
Hhalbar
Default Lower control arm
Hi I just want to know from where did you buy the pushing for lower control arm I bought my from Psb and then not really good
Hhalbar is offline   Reply With Quote
Old 10-24-14, 06:44 PM   #70
tech123
Default Purchase of Bushings
I own a 2007 LS 460 Base and I need to change all of the upper and lower control arms bushings. Would like advise on the number of bushings needed for this job and where can I purchase them?
tech123 is offline   Reply With Quote
Old 10-24-14, 06:48 PM   #71
tech123
Need the same job. Where do I purchase bushings?
Old 10-25-14, 08:58 AM   #72
roadfrog
roadfrog's Avatar
Quote:
One of the vendors sells them here for about 150 bucks. You'll find them through the search function.
roadfrog is offline   Reply With Quote
Old 10-26-14, 05:22 PM   #73
cpcc
Any word on the ride yet?
cpcc is offline   Reply With Quote
Old 01-31-15, 03:26 AM   #74
Thebo
Good day, i have the same problem with my ls 460. And i would like to order only the bushings for the left and right side. Can you help from which site you ordered ?
Kind regards
Thebo is offline   Reply With Quote
Old 03-03-15, 07:38 AM   #75
JMac1035
JMac1035's Avatar
Quote:
Originally Posted by robert1408 View Post
I'm scheduled into my former shop shop foreman's new shop Monday afternoon to replace all eight control arms on my '07. This car has had a slight pull to the right since new so I also got both positive offset upper brackets to raise the camber on the left side and the forward bracket for the right side to raise that caster some. The local Lexus dealer in Austin had all the parts in stock. They gave me net pricing on parts, $2713.28 with tax for all of it. The parts manager there says they sell lots these arms and brackets.
This shop only charges $70/hr. and I'm guessing about 4 hours for this. If all goes well, I'll get the alignment done Tuesday morning. I'll post results in a few days after some driving.
Great info on your posts! I have a 2011 LS460L, no air suspension. Just had my lowers replaced by the dealer under warranty, and now my front end is 1.5 inches higher. Took it back, thought maybe they put the wrong part on possibly. They said it's correct and that's just how it is.
Took the car to a different dealer, and they loosened/retightened the parts with the suspension in it's normal ride height. It seemed to help a little bit, but still looks kind of high to me.
I thought these parts might fix a noise problem that I hear whenever i step on the brakes. It's not a loud noise, but light knocking sound. I replaced pads/rotors as well, still didn't fix light knocking noise i hear when braking at slow speeds.
In trying to fix one problem, it seems like I have a new one now with the front ride height.
I'm open for any suggestions or feedback. I have brought up the brake actuator to their attention, but they say that "it is normal noises"....
Help !!!!!!
Thanks in advance everyone!
Jeff
JMac1035 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
NOVEL Headers. RichieISF IS F (2008-2014) 93 11-12-14 01:21 PM
Aussie ISF RichieISF IS F (2008-2014) 21 04-28-12 09:55 PM
Best coilovers ??? connorsc Suspension and Brakes 37 10-22-10 11:19 AM
Had to put the work wheels aside my winter wheels for only 300 bucks teamavr GS - 2nd Gen (1998-2005) 15 10-29-09 11:42 PM
Random pic i took of my lex and my x5 teamavr GS - 2nd Gen (1998-2005) 6 09-01-09 12:21 PM
Tags
2007, 460, arm, arms, armstrong, bushing, bushings, control, distributors, feedback, forum, lexus, lower, ls, ls460, rear, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
