2008 LS460L starting problems
Old 01-06-14, 03:09 PM
tpeeler099
tpeeler099's Avatar
Default 2008 LS460L starting problems
Hello I am having problems starting my car. It takes 5 or 6 tries . It will not turn over it will just click under the hood. I scanned the code and it showed the crankshaft sensor code. Would this be correct or could it be the starter or starter components. Thanks for your help it is a 2008 LS 460
Old 01-06-14, 03:19 PM
1Putt
1Putt's Avatar
If u haven't already, get the battery and alternator tested
Old 01-08-14, 11:08 PM
SBlexus
SBlexus's Avatar
I would go with the scanner.
Old 01-09-14, 07:43 AM
Devh
Devh's Avatar
Its probably a false code because the charging system is weak. I would test the battery before anything else.
Old 01-09-14, 07:53 AM
jud149
jud149's Avatar
Clicking generally involves discharged or bad battery or battery cable problems. As said, check these items first.
Old 01-09-14, 08:55 AM
caha14
caha14's Avatar
This may be a long shot, given the crankshaft sensor error code, but there is a known problem with the start switch on the LS that manifests itself in a similar manner. There is a TSIB for it; just do a search. If the car is ultimately starting and does so consistently, I would be hard-pressed to think it's a battery/charging system problem.
Old 01-09-14, 09:50 AM
Tee
Tee's Avatar
Sounds like the batt is done, I would start there first.
Old 01-10-14, 11:19 AM
AznRacer
AznRacer's Avatar
I had this problem a few month back. At first I thought my battery was bad. So I took it out and went to autozone to check and the battery was fine. I even bought a new battery just to make sure and it still wouldn't start. I had to tow my car to lexus for them to diagnose the problem and it turn out my starter went bad.
Old 01-10-14, 12:51 PM
jud149
jud149's Avatar
Which of your cars had the problem?
Old 01-10-14, 01:11 PM
caha14
caha14's Avatar
Of course, that makes sense... I didn't pay close enough attention to the OP's reference to clicking; it sure does sound like a solenoid or the starter itself, not the Start switch (even thought that's still very much a known problem).
Old 01-10-14, 03:09 PM
AznRacer
AznRacer's Avatar
My 09 LS460
yyymmm31
09-20-23 01:53 PM
Agamimno
09-12-14 03:27 PM
DaveN
02-07-13 11:16 AM
thinkin
06-03-11 06:13 AM
criminalR1
02-23-09 11:24 PM
Quick Reply: 2008 LS460L starting problems
