A Couple of Repair Questions...08 LS 460
So I was driving on the highway for about 45 mins and the Tire Pressure System Warning light comes on for 5 mins and then turns off. I then check the tire pressure on all the tires using the console and they are all good to go. I also have Costco put air in my tire at the beginning of every month. Do I need to do anything regarding this?
I have problems with my lights turning off. After reading many threads regarding this topic, I should assume it's a bad door sensor? How much are these? I like to order my parts and then have Lexus fix them.
I started to experience terrible wind noise by the drivers side window last week. I looked into this further and noticed when the windows closed, the small rubber barrier that goes outside the glass gets pinched and wind gets inside the window. It happens at the last second the windows pushes against the entire frame. I have to hold the rubber back and have someone else close the window slowly to reduce this noise. As soon as I roll down the windows and back up, it's going to be bad again. Should Lexus cover this?
I have an 08 LS 460 with 55k miles on it.
I can't help you with the first two questions. As far as the third one, if you have the Lexus Platinum Extended Warranty, I am certain it is covered.
Here is a link to an online source for the switch: http://www.oemtoyotascionparts.com/o...tch/8423150190
Here is a discussion about the problems associated with switch: https://www.clublexus.com/forums/ls4...rning-off.html
I was locked out of my account for a bad password and couldn't respond. The password retrieval feature on the board was not working correctly. =]
Anyway, even if I press the alarm ON, the lights still stay ON. Very frustrating. The wind noise is driving me insane. Any ideas on what I can expect on a charge?
I am getting my oil changed there on Wednesday and they are going to look the car over. I purchase all my oil at Walmart and bring my own filters. =]
The lights-staying-on condition is caused by a defective DRIVER'S DOOR JAMB SWITCH. If you really want to do it on the cheap, you can probably switch the driver's switch with one of the other door jamb switches. A defective switch on any door other than the driver's door will not cause the headlights to stay on except in some very special situations that you are unlikely to encounter. A new part is only about $20 and tools are a T-30 Torx bit, socket and drive. Labor is less than 5 minutes. If you are not a DIYer then go to a Toyota dealer or an independent mechanic and point to the switch and ask how much to change it.
Also, how much is are they charging for the NAV upgrade? I always use my phone so I see no need on upgrading the NAV esp. when they want HUNDREDS to do it.
I have the same issue with the driver's door rubber window seal. 2008 w/ 75k mi. No Lexus extended warranty and no third party warranty.
The problem area on mine is the top 2-3" on the vertical part of the window. With the window rolled down, I pried that portion back with my fingers and held it there in an effort to bring it out more so it doesn't pinch in when rolling up the window. I also tugged at the top corner area of the seal also. I then rolled the window up & down several times and was fine. It's only been a few days, but fine so far... knock on wood. Hopefully it doesn't start going back to bowing inwards again.
If you have the Lexus extended warranty, they should replace the seal under the warranty. To me it's a defect and not a wear and tear issue or item (i.e., rubber cracking, etc.)
I wonder what the cost associated with that would be to just fix the seal.
This has been a terrible day! LOL I need some help my friends!
They are charging me $400 dollars to fix the window.
I have less than 60k on my 08 LS 460 and he says I need new Control Arms? This cost is around 4k. What are my options to get this done cheaper? Can I order parts online? ROARRRRRRRRRRRRRRRR =[
Yes, there are cheaper options. Several members have posted info on this forum. Do a search for control arms. You may have to read through a few threads, but you will find some helpful info.
