Rumble from rear
Old 08-03-13, 09:57 AM
Zilla48
Zilla48's Avatar
Default Rumble from rear
For several months there has been a rumble from the rear like suspension is faulty but inspection of strut and other parts showed no obvious issues. 60,000 miles one owner that needs help.
Always services at the dealer. Comments?
Old 08-03-13, 01:04 PM
Valley101
Valley101's Avatar
Default Rumble in Rear
Did you get the tech to take a ride down the highway with you so he could hear what you are talking about?
Old 08-04-13, 01:01 AM
lbintab
lbintab's Avatar
Could be toe wear on the tires
Old 08-04-13, 01:45 AM
lex460l
lex460l's Avatar
i have 2 rear struts that needs replacement but lexus doesnt want to do it, these cars have suspension problems so i dont know what advice to give you, if anything changes for me ill let you know and plz do the same
Old 03-28-14, 01:39 PM
pfiedler
pfiedler's Avatar
I have the same problem...showed up about 3,000 miles ago. My 2010 LS460 has just under 49K on it. Extended warranty. Plan to have it checked out by the dealer at the 50K service.
Old 03-28-14, 01:57 PM
greg3852
greg3852's Avatar
I have 54k on mine, and my right rear strut was done by the previous owner at 45k.
Old 03-31-14, 03:12 AM
pfiedler
pfiedler's Avatar
I'm betting that's the problem with my '10. I'll be getting the 50K in the next 2-3 weeks and will report back to the forum what I find out.
Thanks for the feedback!
Old 04-01-14, 02:13 PM
lexlife66
lexlife66's Avatar
I had to replace both struts on my LS460 L with 64K miles. Luckily my extended warranty company paid for all except $100. If your warranty has a clause that says it will replace an item if it is not functioning as designed you may be able to fight for payment. Even though a strut may not be leaking, if it is making noise, it is not performing as designed.
Good luck
Old 04-01-14, 03:03 PM
sktn77a
sktn77a's Avatar
Pretty much all extended warranties exclude "shock absorbers". A strut is basically a shock absorber - anybody had their struts replaced under an extended warranty or CPO?
nccareer
RX - 1st Gen (1999-2003)
21
05-12-23 07:13 AM
jallegrett
01-14-17 03:25 AM
ThumperPup
ES - 5th Gen (2007-2012)
12-19-15 11:47 PM
biacs
05-05-15 12:11 PM
LauraKay68
GX - 1st Gen (2004-2009)
11-21-10 09:45 AM
Quick Reply: Rumble from rear
