07 460 Strut Replacement DIY
Old 07-01-13, 04:38 PM
Amai21
Amai21's Avatar
Default 07 460 Strut Replacement DIY
Has anyone came across a DIY for front strut replacements? I've had no luck searching. Please help. Thanks.
Old 07-01-13, 08:18 PM
Amai21
Amai21's Avatar
Anybody!?!?!?!
Old 10-12-13, 04:43 PM
Woosside13
Woosside13's Avatar
Default any luck
I need to replace front struts on my 2008 as well, were you able to change it? if so then do you have any type of instructions.
Old 10-12-13, 06:39 PM
is150
is150's Avatar
Instructions would be nice but does anyone have the suspension components torque specs?
Old 10-12-13, 10:09 PM
lbintab
lbintab's Avatar
If you have any mechanical know how the front struts are easy! If you look at it it shouldn't boggle you. Torque specs...tight...haha just not too tight on the upper mounts.
Old 10-19-13, 07:33 AM
Amai21
Amai21's Avatar
Once I figured out that the you disconnect the lower arm (at chassis) it was straight forward. Keep in mind you will be using temporary support to hold up the arm until you have everything disassembled. If you have another jack, that will do the job! Also, you will be disconnecting the stabilizer link.
Removing caliper, rotor, brake cover is NOT necessary at all.
The only thing that is bothering the **** out of me is that the fender gap is ugly. Either its because the rear struts are old and has over 100K on them, or it the lower insulators have an issue.
Anybody experience this problem? If so, what was your fix?
Old 10-19-13, 11:24 AM
derpie
derpie's Avatar
Sure wish there were some pictures to this thread
Old 10-19-13, 09:08 PM
lbintab
lbintab's Avatar
You don't have to remove the lower control arms. You just have to remove both upper control arms from the spindle. The other end of the upper control arms attached to the car can stay in place. Takes maybe 10mins to remove each strut from the car.
Richardsr
16
11-04-18 07:28 PM
robinc2
01-22-18 11:22 PM
hc1001
01-11-17 09:44 AM
RVamiri
Suspension and Brakes
12
06-18-12 11:47 AM
playa3uhh
03-12-08 12:33 PM
Quick Reply: 07 460 Strut Replacement DIY
