After installing wheels/tires/alignment, has radial pull to the right.
Old 06-03-13, 01:30 PM
Grouchy
Grouchy's Avatar
Default After installing wheels/tires/alignment, has radial pull to the right.
I posted this in the tire subsection but its kinda dead over there.
I got them installed and took it in for an alignment at a well known alignment shop. They informed me my caster is dead straight but my car is still hooking right. They told me one of my front two tires are defective.
I took it into American/Discount Tire Co twice and both times they told me my tires are fine. Except this time they told me my wheels weren't true. One of the wheels rim average was .011". Called the alignment shop again and told them what happened. I was told it shouldn't make a difference on car pulling. Even asked a few people and they told me it shouldn't really make a difference in alignment.
The alignment shop told me to ask them to rotate the tires. So I went back and asked them to rotate. They are directional tires but just put them on to test. The radial pull to the right is gone. They told me they would flip the tires but I figured it would just do the same thing all over again.
Any ideas? I've gone to American/Discount Tire 3 times already for the issue. They kept telling me my tires were fine and it was something else. I even showed them the work order from the alignment shop stating it has a radial pull to the right.
Old 06-03-13, 08:24 PM
FLYCT
FLYCT's Avatar
Sounds like you have a bad front tire. Ask them to dismount and remount the two front tires on opposite rims to see if the problem moves with the tire, not rim.
I dont like directional tires.
JR
Old 06-03-13, 08:35 PM
Grouchy
Grouchy's Avatar
JR
Tomorrow morning I'm supposed to go back to dismount and remount on opposite sides. From what I've been reading up, if dismounting and remounting fixes the issues, it means I have a defective tire regardless. Seeing how it fixes the issue with just rotating the whole wheel, doesn't it mean the tires are defective?
I just don't want to waste my time going there, waiting for them to dismount, then remount, take it for a test drive, then realize its still an issue.
Old 06-03-13, 08:43 PM
lbintab
lbintab's Avatar
It's actually a common issue with LS's
Old 06-03-13, 10:39 PM
FLYCT
FLYCT's Avatar
Read these 2 TSBs
http://www.lambros.net/LexusTechInfo...SB-0174-08.pdf
http://www.lambros.net/LexusTechInfo...SB-0035-08.pdf
JR
Old 06-04-13, 07:12 AM
Grouchy
Grouchy's Avatar
Is this the same with aftermarket wheels?
Old 06-28-13, 11:11 AM
hecyen350
hecyen350's Avatar
mine happened the same. i've went to Wheel Work for 3 times and after all the front still pull to the right. tires getting worn real fast. so im putting my stock wheels back .
Old 06-28-13, 11:45 AM
LScowboyLS
LScowboyLS's Avatar
also, make sure these shops are doing a "road force balance" - all Lexus dealers I know of have this machine as do many independents
Old 06-28-13, 02:21 PM
Valley101
Valley101's Avatar
Default Tires/Wheels pulling to Right
It is not common in all LS's. Read the pdf. It only relates to 2007-2009. I had a 2010 and now a 2012 and no problems. I do not have the standad alloy wheels and I have a different version of the Michelin tire than what they normally come with when using Michelin's.
Old 06-28-13, 05:24 PM
Grouchy
Grouchy's Avatar
After going back to American Tire Co about 5 days, we finally narrowed it down to the right front tire. They swapped it out for me and the radial pull is gone. Only took about 6 times going back but its finally fixed!
Old 06-29-13, 02:21 PM
FLYCT
FLYCT's Avatar
I told you so!
JR
Old 06-29-13, 04:43 PM
Grouchy
Grouchy's Avatar
I told you so!
American Tire Co kept denying it was a tire issue. It wasn't until the 5th time going that they finally acknowledged it. At one point one of the tech straight said "don't believe everything you hear at the alignment shop, we do tires, we know more." LOL
Old 06-29-13, 07:56 PM
I8ABMR
I8ABMR's Avatar
very happy that you got it sorted out. There is very little more annoying than an unsolvable car problem. Especially when your car is nice
Grouchy
Wheels, Tires & Brakes Forum
06-12-13 08:33 AM
VTLexus
05-13-10 11:28 PM
thomastan
04-24-09 08:59 AM
IS_Sunny
Suspension and Brakes
30
12-19-08 12:05 PM
GS4Will
10-31-01 01:40 PM
Quick Reply: After installing wheels/tires/alignment, has radial pull to the right.
