please help with DRL questions
Old 01-04-13, 12:12 PM
linus73
linus73's Avatar
Default please help with DRL questions
i ordered a vled 9005 6k kit, installed it in the hgigh beam location, but they will not turn on! if i take out the kit and power seperately they work!. and if i turn on the high beam there is power present. so what am i doing wrong?, i did my last drl kit on my IS 250 and had no isues
Old 01-04-13, 04:14 PM
farming
farming's Avatar
Reverse the connecters? I had to do that for my fogs even though they fit perfectly . Really odd. Lol
Old 01-04-13, 05:19 PM
linus73
linus73's Avatar
i found out that i have bad decoders! i had a set of decoders from jdm toy laying around, so i tried them but they are huge and wont fit in the housing, but they do work now! so vled decoders are bad! or either the wrong ones, even when i took out the vled kit and powered it with a 12v battery they worked, but when installed in the car fitted perfect or reversed the connector, it would not work!. so my only guess is the decoders are bad for my car. thanks for the help! i ended up just using the vled bulbs and the jdm decoders and it works perfect, even flashing the high beams is no problem for the jdm decoders, i remember with my IS i could not flash the high beam or the fuse would blow. no i have no covers over the back of the high beam housings, untill vled sends a new set. wtf?
Old 01-25-13, 01:15 PM
broken_tsi
broken_tsi's Avatar
Can you post pics of everything? What happens when you flash the high beams?
Old 01-26-13, 01:43 PM
RandyV
RandyV's Avatar
Did you get it to work! Let us know! We hope so!
Old 01-27-13, 07:02 PM
Grouchy
Grouchy's Avatar
This may be a stupid question. What happens with your high beams when you replace it with the DRL?
Old 02-04-13, 12:35 PM
supralative
supralative's Avatar
Depends on the strength and numbers of SMD's that you have on the bulb.
My IS250 has 102SMD's and still actually function decent as high beams, but not like a normal halogen bulb high beam.
Only difference though might be that the LS460 is a project housing while the IS250 isnt so not sure how that will affect light output.
Knowing this I will probably order the same kit I used on my IS 250 for my father's LS460 now has well. Just will see how will it works but its not too much money lost at all.
Drofseh
SC- 1st Gen (1992-2000)
06-10-16 01:42 PM
Luke27617
12-19-14 05:47 PM
Meraki Autoworks
IS F (2008-2014)
07-31-12 02:07 PM
IS_NIICE
02-14-08 03:39 PM
Quick Reply: please help with DRL questions
