tire pressure sensor , movable ?
Old 07-18-12, 01:33 AM
aazz
aazz's Avatar
Default tire pressure sensor , movable ?
Hi guys ,
I am planning to change my rims in my 2010 LS460 AWD from 18' to 19' (probably after market not OEM ) , my question is about the pressure sensor , is it movable to the new rims ?
would that cause any problem, should I worry ?
thanks
Old 07-18-12, 02:11 AM
Falbz
Falbz's Avatar
No they should move over with no problems. I went from OEM to 22s with no issues.
Make sure you get a great alignment as our cars have a tire pull issue.
Old 07-19-12, 07:49 PM
tennisstar
tennisstar's Avatar
2nd that!....especially if u also add springs to lower car....even trickier.....still haven't found solution To that camber issue yet so I burn thru more tires than necessary...prolly have to goto coilovers...
Old 07-20-12, 11:55 PM
aazz
aazz's Avatar
thank you all
that was helpful
fsz
02-02-19 02:01 PM
dcurcio
GX - 1st Gen (2004-2009)
10-17-11 07:57 AM
angelslex
04-23-05 12:43 AM
Quick Reply: tire pressure sensor , movable ?
