automatic headlights not turning off - Page 2 - Club Lexus Forums
Thread Tools Search this Thread
Old 06-05-12, 10:49 AM   #16
Mikey100
Quote:
Originally Posted by ehaze View Post
more headlight fun.
parking in my garage:
lights set to automatic
turn the car off
doors are all closed
did not lock the doors
go into the house
lights turned off
gas station this morning:
turn the car off
lock the doors (FOB, one click)
lights turned off
office parking garage:
turn the car off
lights did not turn off
Difference between the gas station and office?
I back into my office parking spot and I was close to the car when I locked it.
I have determined through scientific investigation and irrefutable testing that his is all somehow related to whether the Bass are biting that day.
As crazy as it seems, I now know that this relationship is there.
Hopefully this factoid will help y'all get to the bottom of this dilemma.
Always happy to help out, Mikey Lulejian - Lake Oconee, GA
"Never ever let facts get in the way of a GOOD STORY !"
Mikey100 is offline   Reply With Quote
Old 06-05-12, 11:02 AM   #17
jmcraney
jmcraney's Avatar
Dr. Avogadro, you need to return to your lab.
jmcraney is offline   Reply With Quote
Old 10-24-12, 09:51 AM   #18
purliss
I am having intermittent trouble with my headlights not turning off when in the automatic mode. Doors shut. Even stay on when key fob lock button pushed twice. Drained my battery now twice. No problem detected at the dealer. What do I do? 2006 Lexus GS 300
purliss is offline   Reply With Quote
Old 10-24-12, 10:40 AM   #19
ehaze
my year old battery died so i took the car into the dealer.
dealer blamed the auto headlight issue on the battery.
my 2 cents...
the auto lights failed, causing the battery to go dead (more than once).
ehaze is offline   Reply With Quote
Old 10-24-12, 10:42 AM   #20
ekim
ekim's Avatar
Quote:
I have this same issue w my 07 ls460. Pressing lock button 2 even 3 or 4 and it still doesn't turn off. It will lock my car but lights stay on. This does not always happen.. Maybe once a day or so.
ekim is offline   Reply With Quote
Old 10-24-12, 11:42 AM   #21
jmcraney
jmcraney's Avatar
Quote:
These are classic examples of the door position sensor/switch that is stuck in the closed position. It is very easy to emulate and that is exactly what happens. One of our very wise forum members has posted a video that shows this happening.
You can view his video in this thread: http://www.clublexus.com/forums/ls46...-wont-set.html
One of the other contributors, who works in the automotive repair business, has said that failure of these switches in several Lexus models is very common.
This may be an intermittent condition and difficult to demonstrate, however you should have all your door position sensor/switches replaced. This is also a serious safety issue and the NHTSA may force a safety recall, so, if your dealer will not replace the sensor/switches at no cost then be sure to save the receipt.
Old 10-30-12, 06:44 AM   #22
ehaze
Quote:
I swapped the front door switch with one from the rear. Three days in and no issues with the interior light or headlights!
Dealer said the door switch is $22.
If the fix holds, I'll replace the broken switch.
*Replacing the switch takes all of 5 minutes.*
Old 10-30-12, 09:52 AM   #23
FLYCT
I was the one who posted the videos of my Intermitant curtesy light switches on the driver door. The passenger door switch was also Intermitant but not quite as bad.
If they are $22 and it only takes 5 minutes, change them all and be done with it. Mine was still under factory warranty so I let the dealer do them. The new switches are much more positive actuation and the spings seem stronger.
JR
FLYCT is offline   Reply With Quote
Old 03-31-13, 10:01 AM   #24
USCRugby
Great post guys! I recently have experienced this problem!
USCRugby is offline   Reply With Quote
Old 03-31-13, 10:05 AM   #25
ehaze
few months in, no issues with headlights staying on.
little $20 part fixed the issue.
Old 04-01-13, 11:44 AM   #26
Milon
Do you have the part number for this part?
Milon is offline   Reply With Quote
Old 04-01-13, 07:45 PM   #27
jmcraney
jmcraney's Avatar
Quote:
If you want to buy a new part, it seems that you just order it by the description "door jamb switch." A key word search using the term "jamb" will get you there. I've looked and looked and everywhere, Sewell or Parkplace and others, you just order a "door jamb switch." I think in most of the cases of this "headlight staying on" problem a bad switch is not the cause. However, replacing the switch will likely fix the problem but the fix may not be permanent. The fix likely comes from removing the switch mounting screw and re-torqueing it. I will try to provide some details in the next few days.
Old 04-02-13, 07:13 AM   #28
Milon
Interesting, as I will wait for your response before ordering a new door jamb switch... I did notice that mine intermittently works, so something is not right whether it be the switch itself or the torque setting where it may have loosened over time...
Old 04-02-13, 07:19 AM   #29
jmcraney
jmcraney's Avatar
i don't think it is a torque issue. The problem may be corrosion. Why don't you do us a favor and run the mounting screw out and back in and tell us if that seems to fix it.
Old 04-04-13, 10:36 AM   #30
jmcraney
jmcraney's Avatar
We have seen this problem about the headlights failing to turn off automatically come up several times and we have had numerous reports of premature battery failures and mysteriously dead batteries. One of our astute members, FLYCT, has shown us how the switch that senses the driverís door position is related to these events. Iíve learned that the conventional name for the switch is Door Jamb Switch (DJS) and it is a sort of generic item and the same part is used in most Toyota products.
During my several years of searching the Internet for reports of ďwind noiseĒ I looked at lots of Carfax reports for LS460s that were for sale. Some of the most common entries were multiple battery replacements and multiple notations that the charging system had been checked.
In light of what we know today, I suspect all these battery problems were related to the DJS or its associated circuitry. A problem with the DJS would only cause a battery problem if the headlights were on when the ignition was turned off and the driver was the only person in the car and he didnít open one of the other doors or trunk after he exited. The fact that there are so many reports makes me think that the DJS problem is more pervasive and subtle than we have so far appreciated.
Of course the switch can fail because of latent manufacturing defects, damage, end-of-life or other causes. In our discussions we seem to be at the point of believing that the DJS failure is causing these problems and that may be the case in some of the events. But there may be another cause to consider.
In my quest to find a part number for the LS460 DJS I found this very interesting thread in the Club Lexus Forums GS-Third Generation: http://www.clublexus.com/forums/gs-t...or-solved.html
I have been concerned about my car developing this problem and I take the extra precaution of extinguishing the lights with a double-press of the remote key Lock button each time I leave the car and the lights are on.
Because of my concern I decided to remove the DJS on one of my doors to see if the design was the same a described by the GS owner above. And, indeed it is. The harness to the DJS is a single wire and the DJS body is designed to be electrically bonded to the vehicle chassis via the mounting screw. When the door opens, the switch closes, providing a ground connection to the single wire attached to the switch, indicating that the door is open. A loss of the electrical bond would be the same as the door never indicating open. The bond is a pressure connection on the switch body and a thread connection at the nut-plate in the car via the mounting screw. Some potential problems would be inadequate torque of the mounting screw, or improper passivation of the screw. Passivation issues could range to poor coating conduction to inadequate corrosion prevention. If you continue to have problems after you change the switch be sure to consider the screw.
There was no evidence of corrosion on my switch or mounting screw. I did a bonding test of the screws on the other three doors and they seemed adequate and about the same as the door where I removed and reinstalled the DJS.
I found a thread in one of the other LS460 Internet forums that was interesting in relation to this subject. This is probably a second order failure effect and unlikely to be a problem for most of us. I can tell he didnít go for my advice. Check this: http://us.lexusownersclub.com/forums...ff-on-its-own/
Here are some pictures of the DJS on my front passenger door:
Thread Thread Starter Forum Replies Last Post
What happens to headlights if you shut off car AFTER you open door ? joegoersch RX - 3rd Gen (2010-2015) 16 10-27-16 07:25 AM
Auto light off fault unsw2 GS - 3rd Gen (2006-2011) 2 07-23-15 12:16 PM
Automatic Headlights not turning off lowfunk99 ES - 1st to 4th Gen (1990-2006) 0 03-23-15 05:08 AM
Do Automatic light off system turn off parking lights? Lohus IS - 2nd Gen (2006-2013) 12 02-18-15 09:49 PM
Aftermarket HID Question 2JZSHOTTAZ IS - 1st Gen (2001-2005) 9 01-19-12 08:52 PM
Tags
2007, auto, automatic, battery, cars, headlights, lexus, light, lights, ls460, park, start, switch, turning, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
