How to access rear subwoofer.. Blown/Rattling
Old 05-27-12, 04:52 PM
JBlaze760
JBlaze760's Avatar
Default How to access rear subwoofer.. Blown/Rattling
Hello, I'm trying to access my rear subwoofer in my 07 LS 460 with Mark Levinson. It seems to be blown or ripped somewhere as it makes a loud noise when it hits. Will the top grill just pop off? Or do I gotta do a full removal? If so, how do I get to it. Been reading on these forums for months and always find out help without having to ask, but couldnt find any detailed info. Thanks in advance!
toyo5oh (12-15-22)
Old 05-27-12, 06:35 PM
cmasten
cmasten's Avatar
no easy task. The rear decking must come out and in order to do that you need to remove the rear seats completely. You start with the bottom cushion, (assuming you have a standard model with no Executive package) and it pulls straight up, then you need to find the bolts holding the back cushions on and once the bottom and back are out, you should be able to see the access points for the rear deck that is covering up the subwoofer.
mambo619 (06-26-19)
Old 05-28-12, 02:18 PM
JBlaze760
JBlaze760's Avatar
Thanks for the reply. Now are there different types of executive packages? My rear seats are power and do recline somewhat, but there isn't any foot recliners or massagers.
Old 05-28-12, 03:12 PM
Nick2JZ
Nick2JZ's Avatar
Your probably have the same rear entertainment like mine. Make sure to the move the rear seat all the way forward, and with two hands grab the seat cushion pull straight up. My woofer just went out this weekend too. Have you find out how much Lexus is charging for the woofer?
Old 05-28-12, 09:48 PM
JBlaze760
JBlaze760's Avatar
No. I heard they sell on eBay for $300-$400. Most people said they just tear on the edges causing it to flutter. Was told its an easy fix if so with some kind of epoxy or silicone. And it's suppose to sound better than new. Also was just thinking of replacing it with a JL Audio.
Old 05-28-12, 09:59 PM
Nick2JZ
Nick2JZ's Avatar
please keep us update on which direction you decide to fix. I am noob when it comes to stereo stuffs. I am really disappointed with ML system....... i had to replaced the woofer & amp on my 01' LS430. I guess won't be too long before the Amp. goes out as well.
Old 05-29-12, 02:32 PM
rico9803
rico9803's Avatar
I am also interested in which direction you decide to take and how it works out for you. My sub just recently blew and I'm trying to determine my action plan.
Old 05-29-12, 05:33 PM
ehaze
ehaze's Avatar
i have an 08 SWB with a normal seats.
this coming weekend, i plan on pulling the factory sub. will be sure to take pics and post an EDU/DIY.
Old 05-29-12, 05:46 PM
CJITTY
CJITTY's Avatar
Dang...for real son? Sux
Old 05-29-12, 07:12 PM
rico9803
rico9803's Avatar
It is no joke, I have to keep the volume below 30, and lower the bass so you can't tell. Not only that but my rims have to be repaired.
I just want this nightmare to end and all my wife can say is, you should've got me my mini-van.
Old 05-30-12, 09:57 AM
GSP David
GSP David's Avatar
must've been bumping full bass at max volume lol
Old 05-30-12, 06:27 PM
305Busa
305Busa's Avatar
My sub started ratteling and I removed it but the foam wasnt torn. It seemed to be coming from that funny cone they have. It has some inverted cone. I just left it out and added an aftermarket sub.
Old 05-30-12, 11:02 PM
JBlaze760
JBlaze760's Avatar
What type of Sub did you go with? And how does it sound/handle?
Old 05-31-12, 12:47 PM
305Busa
305Busa's Avatar
I didnt replace the sub, I had an enclosure build with a beautyboard put in the trunk. It sounds a lot better than it did before. More of my taste.
Old 06-02-12, 04:20 AM
ehaze
ehaze's Avatar
power rear seat removal:
https://www.clublexus.com/forums/6326071-post185.html
Quick Reply: How to access rear subwoofer.. Blown/Rattling
