ls transmission problem
Old 06-13-16, 03:25 PM
v8haha
v8haha's Avatar
My 2007 lexus has started making the shuttering noise. I took it to the dealer and they told me its the torque converter. I have read that doing a flush may solve the problem or else the transmission will need to be replaced. My local mechanic (who is a very competent) said its rate a torque converter will go bad on its own and if a flush doesnt help, i most likely need to rebuild the tranny.
For those who have the shutter, has it gotten worse over time?
Old 06-14-16, 03:41 AM
superdenso
superdenso's Avatar
Which car do you have(i.e. AWD)? And what is your current mileage? Have you ever had the transmission fluid changed? Can you describe the noise or is it just a hesitation? Does it happen everytime you accelerate or only under full/aggressive throttle?
Old 06-15-16, 09:51 AM
boz151
boz151's Avatar
Hi everyone, I'll throw in my two cents here. I have a 2013 CPO AWD and have owned it about 5 months now. Over the last couple of months, I have started to feel what I would describe as a shudder from the front of the car when taking my foot off the gas at about 60 mph slowing to about 50 mph. I thought it was the tranny or something in the drivetrain. Today I took it in for the 5000 mile service and mentioned it to the advisor. He has the tech's take it for a ride and they felt the same thing. Contacted Lexus and apparently it is a known issue with the front drive shafts. They ordered them today and will be replacing them both tomorrow. Again, I'm not sure the issue is related to this one since it seems to be a shudder/delay on acceleration, but thought I would mention it if it helps.
Old 06-15-16, 11:12 AM
superdenso
superdenso's Avatar
How often do the AWD owners drain/re-fill the front diff and transfer cases? Does anyone have a schedule that they follow besides "never"? I've heard SUV recommendations that describe changing the transfer case and diff. fluids when a shudder presents,
Old 06-17-16, 12:47 AM
superdenso
superdenso's Avatar
Default The LS AWD is an SUV disguised as a sedan (See below)
Before tackling torque converters and shafts try a great diff fluid--->
POSTED BY: JiffyPop
AWD Transfer Case Vibration Possible Fix
Ever since I purchased my 08 LS600hL it had the common issue of the vibration and noise as described in TSB L-SB-0023-11. I had a hard time believing that there was some crazy expensive magic fluid that would fix the problem. As an experiment I decided to instead replace the fluid with Amsoil 75w90 severe gear. It is a GL 5 fluid and as far is Toyota is concerned an acceptable substitute. It even has a street price of $16 a quart. Far cry from the $120+ the Toyota miracle fluid goes for.
So with the amsoil in hand, I drained the existing fluid and replaced. Instead of driving for 1 mile as the repair suggests, I decided to drive a week to really let the fluid work in. After about 5 minutes of driving the noise and shuddering effectively disappeared. I can turn much more smoothly now.
After driving the car for a week now I'm glad to report that the fix has still worked flawlessly. I will continue to drive for another 5000 miles and at my next oil change if the noise starts to return I will repeat the process and keep this thread updated. Hopefully this can save other Awd owners out there some money!
Old 06-17-16, 10:56 AM
UZ214
UZ214's Avatar
i have the same issue, but it not much evident most of the time to complain. I do feel the vibrations more if i go on a hilly road, when the car dips and comes up- in the exact moment. I got new tires and it didnt really help.
Old 06-18-16, 07:13 AM
roadfrog
roadfrog's Avatar
I don't have AWD, but to answer the question on when to change diff fluid, my manual states every 40k miles or so (I forget the exact number).
Old 06-18-16, 07:29 AM
superdenso
superdenso's Avatar
Default Spec. from a 2009 manual
Transfer Case: 75W-85 GL-5 or equivalent
Front Differential: 75W-85 GL-5 or equivalent
Rear Differential: 75W-85 GL-5 or equivalent
http://www.redlineoil.com/product.aspx?pid=40&pcid=4
https://www.amsoil.com/shop/by-produ...e-gear-75w-90/
http://www.royalpurpleconsumer.com/products/max-gear/
https://mobiloil.com/en/gear-lubrica...c-gear-lube-ls
Old 06-19-16, 02:32 PM
steelers6
steelers6's Avatar
Originally Posted by bobbyc
My 2011 LS 460 with 3800 miles on it has a shutter or modulation at about 38 to 40 mph.Transmiision? Any fixes out there or known problems? Great car but this problem is becoming annoying. I haven't had it into the dealer yet, because I would like to have some input from others so they don't just blow me off
I would personallypurchase a extended warranty as soon as possible,maybe a lower tier one that only covers the engine,trans and drive axle...Good luck...
Old 06-21-16, 12:52 PM
Vansibel
Vansibel's Avatar
Seems similar to what some ls600hl are experiencing (more details on page 2): https://www.clublexus.com/forums/ls-...n-ls600hl.html
anucci
09-18-15 03:00 PM
rtlewis
08-24-14 09:27 AM
edarte
01-15-12 12:05 PM
edarte
03-31-11 08:58 AM
1994 LS400
05-26-02 11:23 PM
Quick Reply: ls transmission problem
