LS 460/600 Wheel & Tire Information Details Thread - Page 3 - Club Lexus Forums
Old 12-15-14, 04:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
Print Wikipost
Thread Tools Search this Thread
Old 08-23-12, 08:55 AM   #31
CJITTY
CJITTY's Avatar
Updated Sep 18, 2012:
LS Year/Model: 2008 LS600hL (All Wheel Drive)
Wheel Brand: VOSSEN
Wheel Model: CV1
Wheel Size Front: 22x9.0
Wheel Size Rear: 22x10.5
Wheel Finish: Silver Matte/Machined face
Lip size front (if applicable):
Lip size rear (if applicable):
Lip finish (if applicable): Stainless Steel
Offset Front: et35 (et20 with 15mm Akata Spacer)
Offset Rear: et38 (et35 with 3mm Akata Spacer)
Hub Bore size (if known):
Hub Centric Rings Required? Y/N: Yes
Tire Size Front: 245/30/22
Tire Size Rear: 295/25/22
Front and Rear Tires have exact same overall rolling diameter for AWD system compatibility
Tire Make/Model: Continental DWS
Tire Air Pressure Preference: 42
Suspension: Data Systems Electronic Lowering Module
Fenders Rolled/Altered: Stock
Does the setup rub?: Not as of yet while driving at level 3 of data controller. Last 3 pics are on Super Low Mode (controller level 9) which is for show only.
Secondary Setup below shows same wheels but with Akata Spacers added
Offset Front: +35 (with 15mm front spacer, new offset is appx 20mm)
Offset Rear: +38 (with 3mm rear spacer, new offset is appx 35mm)
CJITTY is offline   Reply With Quote
Old 09-05-12, 03:52 PM   #32
tennisstar
here's my mild wald setup since nobody has posted it..sorry for iphone pics... ain't got no photog skills anyways like y'all posting
LS Year/Model: 2007 LS460 SWB
Wheel Brand: WALD
Wheel Model: PORTOFINO
Wheel Finish: ALUMINUM (I BELIEVE)
Lip size front (if applicable): DUNNO
Lip size rear (if applicable): DUNNO
Lip finish (if applicable): ALUMINUM
Offset Front: DUNNO
Offset Rear: DUNNO
Tire Size Rear: 285/25/22
Tire Make/Model: Continental DWS FRONTS AND FALKENS 452 REAR
Tire Air Pressure Preference: 42 FRONT 40 REAR
Suspension: TANABE SPRINGS
Does the setup rub?: PROBABLY MILD RUBBING
LS 460/600 Wheel & Tire Information Details Thread-car-shot-1.jpg   LS 460/600 Wheel & Tire Information Details Thread-car-shot-2.jpg   LS 460/600 Wheel & Tire Information Details Thread-car-shot-3.jpg
tennisstar is offline   Reply With Quote
Old 09-09-12, 07:48 AM   #33
telmz1
LS Year/Model: 2009 LS460L
Wheel Brand: VIP Modular
Wheel Model: VR01
Wheel Size Front: 22x9.5
Wheel Size Rear: 22x11
Wheel Finish: Silver polished
Lip size front (if applicable): ~3"
Lip size rear (if applicable): ~4"
Lip finish (if applicable): chrome
Offset Front: no idea
Offset Rear: no idea
Hub Bore size (if known): 60.1mm
Hub Centric Rings Required? Y/N: no
Tire Make/Model: F-Contintal DWS, R- Toyo Proxes
Tire Air Pressure Preference: 40 psi all around
Suspension: Factory air suspension with lowering module
Fenders Rolled/Altered: Rear fenders shaved. Front fender plastic trims removed, fenders rolled
Does the setup rub?: No rubbing unless hitting very bad dips.
LS 460/600 Wheel & Tire Information Details Thread-dsc_1151.jpg   LS 460/600 Wheel & Tire Information Details Thread-dsc_1195.jpg   LS 460/600 Wheel & Tire Information Details Thread-dsc_1178.jpg   LS 460/600 Wheel & Tire Information Details Thread-dsc_1200.jpg   LS 460/600 Wheel & Tire Information Details Thread-dsc_1197.jpg
telmz1 is offline   Reply With Quote
Old 10-05-12, 08:22 AM   #34
G-SharK
G-SharK's Avatar
Wheel Brand: Lexani
Wheel Model: LSS-8
Wheel Finish: Black/Machined with Chrome Lip
Lip size front (if applicable): 3"
Lip size rear (if applicable): 5.5"
Lip finish (if applicable): Chrome
Offset Front: ET25
Offset Rear: ET30
Hub Bore size (if known): 74.1
Tire Make/Model: Nexen 3000
Suspension: Drop with Tanabe Spring on stock shocks
Does the setup rub?: No rub after the fender shave
LS 460/600 Wheel & Tire Information Details Thread-ls460.jpg
G-SharK is offline   Reply With Quote
Old 10-09-12, 05:54 PM   #35
96zenki
96zenki's Avatar
LS Year/Model: 07 LS460L
Wheel Brand:Luxury Abstract
Wheel Model: Mador
Wheel Size Rear:22.10.5
Wheel Finish:
Offset Front:+25
Offset Rear:+25
Tire Size Front: 255/30/22
Tire Make/Model: nitto
Suspension: stock air with data system controller, ride height at setting 5, pictures shown on 8
Fenders Rolled/Altered: rear fenders shaved
Does the setup rub?: when i roll on 5 it rubs on certain bumps not too bad.
96zenki is offline   Reply With Quote
Old 10-31-12, 08:42 AM   #36
DallasLex
DallasLex's Avatar
Wheel Brand: Vossen
Wheel Model: VVS-084
Wheel Size Front: 20X9
Wheel Size Rear: 20X10.5
Wheel Finish: Silver Machined
Lip size front (if applicable): 1.75"
Lip size rear (if applicable): 2.75"
Lip finish (if applicable): Highly Machined Polished
Offset Front: 31mm
Offset Rear: 31mm
Hub Centric Rings Required? Yes
Tire Size Front: 245/40/R20
Tire Size Rear: 275/35/R20
Tire Make/Model: Faulken FK452
Tire Air Pressure Preference: 35psi
Suspension: stock
Fenders Rolled/Altered: No
DallasLex is offline   Reply With Quote
Old 10-31-12, 10:52 AM   #37
BPVIP
BPVIP's Avatar
LS Year/Model: 2008 LS460
Wheel Brand: AGforged
Wheel Model: F440 concave spec.
Wheel Size Front: 22 x 10
Wheel Size Rear: 22 x 12
Wheel Finish: Black Chrome face and lips with Gold bolts
Lip size front (if applicable): 5in
Lip size rear (if applicable): 5in
Lip finish (if applicable): Black Chrome
Offset Front: ?mm
Offset Rear: ?mm
Hub Centric Rings Required no
Tire Size Front: 245/30 22
Tire Size Rear: 295/25 22
Tire Make/Model: Lionhart
Tire Air Pressure Preference: 50psi
Suspension: JIC coilovers and UAS bags with manual set up 2 channels
Fenders Rolled/Altered: front rolled rear shaved
Does the setup rub?: yes slightly on fender liner front and rear
BPVIP is offline   Reply With Quote
Old 11-11-12, 08:31 PM   #38
Pushkar
Pushkar's Avatar
LS Year/Model: 2007
Wheel Brand: Vossen
Wheel Model: N/A
Wheel Size Front:
Wheel Size Rear:
Wheel Finish:
Offset Front: 15
Offset Rear: 20
Tire Size Front: 265 30 22
Tire Size Rear: 295 25 22
Tire Make/Model: Continental <--- AWESOME GRIP
Fenders Rolled/Altered: YES
Does the setup rub?: YES. I took the wheels off after 2 weeks. The wheels were aggressive and I quickly found out that I had lost too much ride quality. They drove awesome in a straight line! I was unable to carry passenger, which is a trade i am unwilling to accept. Thus, I am back to stock after 14 days of the 22s.
Pics Below:
Pushkar is offline   Reply With Quote
Old 11-20-12, 11:52 PM   #39
LXurious
LXurious's Avatar
LS Year/Model:2008 LS600hL
Wheel Brand: MRR
Wheel Model: HR3
Wheel Size Rear:22x10.5
Wheel Finish:Chrome
Offset Front: 32mm
Offset Rear: 35mm
Hub Centric Rings Required? Y/N: No
Tire Size Front:255/30/22
Tire Size Rear: 305/25/22
Tire Make/Model: TOYO Proxe 4
Suspension: Stock Air Suspension
LS 460/600 Wheel &amp; Tire Information Details Thread-img_1056.jpg   LS 460/600 Wheel &amp; Tire Information Details Thread-img_1063.jpg
LXurious is offline   Reply With Quote
Old 12-08-12, 08:04 AM   #40
CJITTY
CJITTY's Avatar
http://www.iapdirect.com/ATEQ_TPMS_R...FQWe4AodmmgAmw
Excellent find by CL member CAHA14. Very inexpensive TPMS tool that allows you to swap your winter/summer wheels without the hassle of paying for dealerships or tire shops to reset your tpms. Many tire shops to this for free if you do business with them..but this appears to be a good tool to have for all your import TPMS vehicles
Old 01-04-13, 07:53 PM   #41
CJITTY
CJITTY's Avatar
Quote:
Originally Posted by Tee View Post
Let's honor the OP's request & keep this thread clean, please PM or go to the members thread ask to questions about their set-up thx!
In order to keep this as a research only thread, please only post if you are adding the template and pics of your setups or adding helpful links about wheel and tire products for the LS
please PM members directly and not comment on photos in this thread, otherwise it really get muddy and the point of the thread gets lost..thanks
Old 01-04-13, 08:32 PM   #42
CJITTY
CJITTY's Avatar
This follow up post shows the 19x8 OEM wheel setup with 15mm spacers up front and 20mm spacers on the rear.
LS Year/Model: 2008 Lexus LS600hL
Wheel Brand: Lexus
Wheel Model: 7 Spoke OEM Hybrid Wheel
Wheel Size Front: 19x8
Wheel Size Rear: 19x8
Lip size front (if applicable): N/A
Lip size rear (if applicable): N/A
Lip finish (if applicable): N/A
Offset Front: 32mm (with 15mm Akata spacer, new offset appx 17mm)
Offset Rear: 32mm (with 20mm Akata spacer, new offset appx 12mm)
Hub Bore size (if known): 60.1 (OEM)
Tire Size Front: 245/45/19
Tire Size Rear: 245/45/19
Tire Make/Model: Bridestone Turanza
Tire Air Pressure Preference: 35psi all around
Suspension: Data Systems Lowering Module
Pics Below:
IMG_20130104_172233 by
IMG_20130104_172346 by
IMG_20130104_172818 by
IMG_20130104_172514 by
IMG_20130104_172926 by
IMG_20130104_174945 by
20130104_175045[1] by
Old 01-24-13, 02:15 PM   #43
linus73
linus73's Avatar
LS Year/Model:2008 Ls460
Wheel Brand: lexani
Wheel Model: cvx-44
Wheel Size Front: 20x8.5
Wheel Size Rear:20x9
Wheel Finish:silver windows,machine face,chrome ss lip
Lip size front (if applicable):2
Lip size rear (if applicable):2.5
Lip finish (if applicable):chrome
Offset Front: na
Offset Rear: na
Tire Size Front:245/40/20
Tire Size Rear: 275/35/20
Tire Make/Model: nitto 555
Tire Air Pressure Preference:40
Suspension: Stock- no air
Does the setup rub? NO
i plan on lowering the car with some tanabe lowering springs in the summer. (edit: it is now lowered! i could not wait lol....02/23/2013)
here is the LS460 after i had the tanabe springs installed, car is dirty ( but its winter)
linus73 is offline   Reply With Quote
Old 01-28-13, 02:17 PM   #44
20GS300
20GS300's Avatar
Default WHeel and Tire Informatoin Details Thread- Lexani CVX-44's
LS Year/Model: LS460
Wheel Brand: Lexani
Wheel Model: CVX-44
Wheel Size Front:22x9
Wheel Finish: silver/machined with SS lip
Lip finish (if applicable): Stainless Steel/Chrome
Offset Front: +38mm
Offset Rear: +42mm
Tire Size Front: 255/30-22
Tire Size Rear: 295/25-22
Tire Make/Model: Pirelli P Zero
Tire Air Pressure Preference: 40 PSI
Suspension: Tanabe NF210 Springs/stock struts (for now-want to put coil overs on car ASAP!)
Fenders Rolled/Altered: no
Does the setup rub?: slightly in certain turns with bumps or hard dips, etc
**If anyone is interested, I will be putting the above wheels (not tires) up for sale(22X9/22x10.5 Lexani CVX-44). I am installing one of the brand new Lorenzo 2 piece forged wheels that just came out last month! They will be a little aggressive with my Tanabe springs (22x9.5/22x11 rear) but I am going to give them a shot. Great looking wheels if you guys havent seen them yet. Same factory that builds the 2 piece Giovanna/GFG wheels.**
http://images.wheelpros.com/mWL1974.png
Lorenzo WL197 with Titanium and machined center with Stainless chrome lip. Forged barrels with cast center. Best part is that they cost less than a one piece Vossen wheel. They have two other styles to choose from and are coming out with other sizes, finishes, etc in the near future.
Read more: http://www.clublexus.com/forums/ls46...#ixzz2JJ4gRasg
LS 460/600 Wheel &amp; Tire Information Details Thread-high-side-angle-with-spoiler.jpg   LS 460/600 Wheel &amp; Tire Information Details Thread-lr-angle-with-spoiler.jpg   LS 460/600 Wheel &amp; Tire Information Details Thread-front-wheel-caliper-close-up.jpg   LS 460/600 Wheel &amp; Tire Information Details Thread-rear-side-angle-2.jpg   LS 460/600 Wheel &amp; Tire Information Details Thread-rear-side-angle-wheel-caliper.jpg
20GS300 is offline   Reply With Quote
Old 02-11-13, 10:22 PM   #45
hecyen350
hecyen350's Avatar
Hi guyz.sorry these wheels i didn't know the offset.
LS Year/Model: '08 Lexus LS460 Smoky Granite Mica
Wheel Brand:MOZ: 2 piece
Wheel Model: Concours
Wheel Size Front:22x9.5
Wheel Size Rear:22x9.5
Wheel Finish:Two tones Silver / Black
Lip size front (if applicable): 4 inch
Lip size rear (if applicable): 4 inch
Lip finish (if applicable): Glossy Black
Offset Front: unknown
Offset Rear: unknown
Tire Size Front: 255/ 30/ 22
Tire Size Rear: 255/30/22
Tire Make/Model: Lexani
Suspension: BC Coils
Does the setup rub?: rub on right front when enter high drive way
Pics Below:
LS 460/600 Wheel &amp; Tire Information Details Thread-dsc00844.jpg   LS 460/600 Wheel &amp; Tire Information Details Thread-dsc00834.jpg   LS 460/600 Wheel &amp; Tire Information Details Thread-dsc00836.jpg
hecyen350 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
CA 2014 IS F-SPORT 18" OEM Factory Stock Wheels Rims Tires daobn24 Wheels and Tires Classifieds 1 09-23-14 08:05 PM
NY WILLING to SHIP- WTS: 19" Staggered AME Shallen CX WITH almost NEW TIRES- MUST SEE!! NYC ES3 Wheels and Tires Classifieds 24 04-26-11 01:36 AM
CA FS: 19's w/tires for $1,000: Luff M1 Gold Mesh 19x8.5/19x10.5 raine Wheels and Tires Classifieds 33 06-08-09 08:56 PM
FS: Rays Lexion 203's w/ tires mrkenji Wheels and Tires Classifieds 13 04-01-08 04:59 PM
For Sale: WALD D23 3-piece Wheels (19x8.5 and 19x10) with Bridgestone S-03 Tires bizdev_guy Wheels and Tires Classifieds 11 09-06-05 10:58 PM
Tags
2008, 22, 24530zr22, 460, 600, lexus, ls, ls460, ls600hl, offset, part, pressure, review, rim, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
