volume knob WON'T adjust volume
Old 12-19-16, 01:53 PM
Jodwin
Jodwin's Avatar
Originally Posted by Higgie
I have repaired mine last year, hopefully i remember correctly:
  1. Remove the DVD-unit, you can find instructions here on CL and Youtube.
  2. Remove the screws that hold the front of the DVD-unit in place.
  3. Remove the front from the DVD-drive. (you have to bend some clips a little bit.)
  4. Resolder the volume button with 60/40 solder, do NOT use leadfree solder. That's why it got loose.
  5. Reassemble
Mine is working fine now.
Very cool and thank you for the information, I am inept at even having a clue on how to do any of this so it looks like it is time to try and bribe a buddy that has a clue!
Old 12-19-16, 02:20 PM
dlbuckls10
dlbuckls10's Avatar
Same here. I wouldn't have a clue and I would probably screw something else up.
Old 12-20-16, 09:16 AM
CRowe14
CRowe14's Avatar
I assure you, taking the dash area apart to gain access to the DVD unit isn't very difficult at all.
Actually, I think you'd be quite surprised at how easy it is. Its just a matter of being very careful and taking your time.
If you could access and remove it and take it to someone to solder it, that could save you some $$ on labor.
From the sounds of it, the process to solder it would probably take 10 minutes at the most!
Old 12-20-16, 10:38 AM
sdwtchlvr
sdwtchlvr's Avatar
Same thing has happened to mine. Comes and goes. To remedy it I press the **** in firmly turning the radio off, then turn back on and it usually works.
I have a warranty for my for my car but the issue happens intermittently so of course it won't happen when I take it in. I can live with for now.
Old 02-23-17, 01:54 PM
1WILLY1
1WILLY1's Avatar
My volume **** just died as well , steering wheel adjust still works
Has anyone found any other causes or fixes to this issue?
Old 02-25-17, 02:08 AM
Junglequac
Junglequac's Avatar
The PO of my car had this issue come up a few years back and had Lexus fix it. I think it came out to $600 or so. I will go through the records as I have every single one since new and will report back with the price and parts ordered.
The following 2 users liked this post by Junglequac:
1WILLY1 (02-26-17), 9918939 (02-18-18)
Old 02-26-17, 01:10 AM
1WILLY1
1WILLY1's Avatar
great thanks man
mine started working again last night but would still be nice to hear what was involved with the repair
Old 07-24-18, 01:29 PM
Teejay73
5th Gear
Teejay73's Avatar
Mine went out yesterday I have the radio out. Any fixes? Or should i try the resoilder? Is there a part number for the volume **** motor?
Old 02-21-19, 03:57 PM
rlm02sc430
rlm02sc430's Avatar
Default Mode controls
Just noticed my mode controls on steering wheel doesn’t change stations like it used to. Volume works fine. Having spiral cable unit replaced tomorrow as horn stopped working- seems this function might also be affected. Anyone know how to bypass the spiral cable for horn. I can do without steering controls for radio (although, it is nice) 2007 SC- did not have these issues with my 2002 sc.
bob in Texas
Old 04-14-24, 02:13 PM
faysal1981
2nd gear
faysal1981's Avatar
2005 rx330 The volume **** does turn the radio off/on, but when I want to turn the volume up, it does not work. no sound, i can see all preset radio stations, FM am, and everything, but the volume up/ down stopped Usually, I get numbers when I turn up or down but it does nothing !!! i checked all connections, (lose or tight )( i did unplug the battery cable for a reason, and after a few days i found out this happened ) i did reprogram the windows and seat, sunroof, but i i have no idea is there anything i have to reprogram in the radio? please help me, can't invest for a sound system
matts6887
09-02-22 05:27 PM
tofu
03-08-17 02:24 PM
Hozy
05-10-16 07:23 AM
aznoutkast
06-15-12 09:46 PM
GSquicksilver
01-17-03 04:49 AM
Quick Reply: volume knob WON'T adjust volume
