shake
They either didnt put hub rings on or they need to rebalance. Make sure you take it to a good shop. Some shops will do a static balance to just get the machine to read that the balance is perfect. Ask for a road force target balance. Tell them you want to see the read out sheets from the balancing. All the numbers for all tires should be below 10-12 g. I took the LS to discount tire and the balanced it. It still felt like crap so I took it to a wheel specialist shop and they found that my rear right was out 29 grams. Thats insane. Discount tire is great for flats and buying tires at low low prices but they couldnt balance a tire to save their lives
Sounds like what I recently experienced. I was getting a vibration at 72-78mph that seemed to be coming from the rear. The tires were balanced twice using load/balancing. Finally we moved the back tires to the front and all the vibration just went away. Like magic. I suspect that having the tires on the front puts more load weight on them; thus some how causing the vibration to go away.
chrispy
CL of Southern California
14
03-04-08 09:47 AM
