engine shroud covers
Old 09-30-11, 08:29 PM
  #31
Mikey100
Mikey100's Avatar
I really appreciate the tip - Especially the photographs.
Best Wishes, Mikey
Lake Oconee, GA
Old 10-01-11, 05:51 AM
  #32
Mikey100
Mikey100's Avatar
Originally Posted by Nospinzone
Yea, but you don't get as many points if they survive, right?
Yes ........ But this only applies if you hit someone while in France @!
LOL !
Best Wishes to all ..........
Mikey
Lake Oconee, GA
Old 07-23-13, 10:27 AM
  #33
Daco
Daco's Avatar
Default Clips online?
do you have a part # or model # for the clips? Has anyone found these online and if so where? I looked at rock auto but could not find them.
Old 07-23-13, 03:15 PM
  #34
Silverpaws
Silverpaws's Avatar
http://www.ebay.com/itm/221210560681 I recently purchased these on ebay. They are identical to OEM and very inexpensive compared to dealer prices. I am cheep! The downside is that your order takes 2 to 3 weeks to arrive from China. You can find them on ebay from U.S. sellers at higher prices. By the way, these clips work perfectly also and can be re-used if you understand how to remove them.
Old 07-23-13, 03:35 PM
  #35
Silverpaws
Silverpaws's Avatar
Also you might want to review this thread: https://www.clublexus.com/forums/ls4...ning-clip.html
Old 07-23-13, 06:43 PM
  #36
tofu
tofu's Avatar
Originally Posted by Newps
Just a heads up on the plastic clips that hold the engine cover on. I recent purchased a 2007 LS 460. While I was getting it smogged the tech and I started poking around under the hood. I grabbed one of the side plastic panels and it just about fell off in my hand. All of the plastic clips popped out and a couple fell into the engine compartment. So I started looking around and noticed I was missing a lot of the plastic clips and the ones that were on there were doing very little at holding the panels in place. The factory clips did not fit the holes as they should have, they were too small for the holes. I went to my local ACE Hardware and picked up a bunch of plastic automotive clips. They had all sorts of different kinds in different lengths and hole sizes. I found some great ones that hold all of my panels firmly in place. I picked about 10 extra ones to use as spares incase they brake or get lost. Let me know if you want me to post up a picture of the clips I purchased.
I heard someone said that Lexus will put new ones for you free if you take your car in.
Old 09-15-13, 11:33 AM
  #37
rpe94
rpe94's Avatar
Default Retainer clips
I have noticed that the battery cover has clips that you push in to release, where the other engine compartment covers have clips that you push the center in to lock.
Does anyone have the part number for each style of clip, so that I can order some?
Thank you,
Ray
Boston, MA
Old 09-15-13, 02:07 PM
  #38
Silverpaws
Silverpaws's Avatar
Ray, you can find the part numbers in this tread: https://www.clublexus.com/forums/ls4...ning-clip.html I believe that you will find that each of the clips work the same if you have factory clips. If you push the center in far enough, the clip will release.
Old 02-18-14, 06:50 PM
  #39
RR601
RR601's Avatar
Tried those. But they do not seem anything like the oem type. You cant push down on the center to remove without a tool. But still good for the price.
Old 02-18-14, 08:16 PM
  #40
scottkroug
scottkroug's Avatar
A quick search pulled these up on ebay
supplier from the USA with quick shipping
The way they first wrote it made me think it was 1000 LOL
100 OEM clips for 23.98
http://www.ebay.com/itm/like/151148837132?lpid=82
Old 02-18-14, 08:17 PM
  #41
Lexus4me
Lexus4me's Avatar
do they have clips in white?
Old 02-19-14, 04:54 AM
  #42
scottkroug
scottkroug's Avatar
Once again a quick search "Hint, Hint" brought up this.. I have used it many times and it works great on plastic.
http://www.ebay.com/itm/SEM-Paint-Carpet-Plastic-Vinyl-Flat-Phantom-White-Aerosol-12-oz-Ea-15003-/191064213834?pt=Motors_Automotive_Tools&hash=item2c7c50894a&vxp=mtr
Old 02-19-14, 06:52 AM
  #43
RR601
RR601's Avatar
100OEM Clips Grille Push Type Retainer Clip for Lexus Toyota 90467 07211 L19 | eBay
I think those are the ones I just got in. The problem with any of the Ebay ones are they don't push down to release. Tried 3 different ones on Ebay.
Old 02-19-14, 07:37 AM
  #44
shrikelex
shrikelex's Avatar
SEM Paint Carpet Plastic Vinyl Flat Phantom White Aerosol 12 oz ea 15003 | eBay
I used a product like that before, back in the days I had two 735i's and changed all the plastic tan color interior pieces to all black, came out pretty good. Far as the 460 for a color change, I'd only consider dyeing the carpet which is grey to black using a professional product, but for now I'll try to clean all the time, ugh..
Old 02-19-14, 08:13 AM
  #45
scottkroug
scottkroug's Avatar
At a cost of $0.24 cents each I can afford to replace a few each time
Which by the way had me thinking when I saw this on e bay last night.
If they cost us $0.24 cents each how much could Lexus pay for a few million at a time?
Makes you wonder!!!
Quick Reply: engine shroud covers
