Turn signal LED
Turn signals require a load to work properly, for a filament bulb, the load is the element for an led you will need to either figure out the resister value to add or just buy an led made for a turn signal
I use LEDs on my Honda pilot for turn signals there were designed for truckers as running lights and have the resister load built into the element
read this doc to get a better understanding of what I am talking about.
http://www.superbrightleds.com/pdfs/...istor_info.pdf
This is a simple loading resister to use any LED you choose, but if you query for LED turn signal etc, you will see various companies that sell them with the loading resister circuitry built in.
Meritline is an excellent company from my dealings, they have some like this, http://www.meritline.com/t20-smd-led...--p-50170.aspx, this is a T20 in size, but may help you get the idea.
I saw some others from ELEF that are stupid bright, but looks like those bulbs require you need to use quick connects on your stock wiring FTL
http://www.youtube.com/watch?v=fVG1MJk05Uc
High-quality external load-resistors get very hot and have to be installed on metal in an area not conducive to fire. So, with the LS460, I decided I didn't want to be bothered with all that again … and just went with an $11 pair of blue-coated #921 Sylvania SilverStar incandescents … that supposedly deliver a much brighter/whiter light (as the expense of delivering only 175 hours of expected life).
Btw, I found that my local O'Reilly counter guy readily understood the LED hyper-flashing issue … and could have assisted in ordering-in the load-resistors I would have needed. Or you can find a pair, or even a quad, on Amazon for about $15.
Get yourself one of these bad boys.
I am using Diode Dynamics smart tap flasher and it works perfectly with any led .
The following 2 users liked this post by ALK:
BlazeViper (07-09-21),
Diode Dynamics (07-12-21)
I installed 7440 Amber LED's in the front turn signals and did not get any hyperflash at all and they look great. But I have tried 3 different sets of amber 921 LED's in the rear and all of the result in hyperflashing. At this point I am considering the relay because I dont want to install resistors.
The flash-relay sits behind the driver's instrument cluster; you have to remove certain trim panels so as to be able to unscrew the instrument cluster hold-downs, then set the instrument cluster aside and then swap-out the flash relay. DIY instructions for pulling the instrument cluster and installing a new flash relay are posted at https://bit.ly/3B04NrS , https://bit.ly/3i9wztD , https://bit.ly/3ecOpuz .
kenaston99
07-13-18 07:56 PM
