how to adjust headlight
Old 04-17-12, 11:22 AM
G-SharK
G-SharK's Avatar
So I found another thread on the headlight adjustments -
On the first gear (closest the front of the car) To adjust the headlight downward, turn the adjusting screw clockwise. To adjust the headlight upward, turn the adjusting screw counterclockwise.
2nd gear (according to CJITTY-far back corner) I cannot find anything related to which direction to turn to adjust - I am assuming you would adjust it the same as the first gear. (as mention above - change both gears with the same rotation location)
Hope this makes sense... Thanks CJITTY and randomwalk posting
Old 04-17-12, 03:15 PM
CJITTY
CJITTY's Avatar
No problem
I assume same direction on 2nd adjustment also..but not sure. This car is like calculus ..just difficult lol
Old 01-27-16, 09:23 PM
philnshelb
philnshelb's Avatar
Originally Posted by G-SharK
Can someone help me, I cannot seem to locate the adjusting screw. Do I remove the black cap (pointed with the red circle). I am trying to move the headlights up, right now its pointed down too low
Thanks,
Ly
So where is the second adjustment ****?
Old 01-27-16, 09:27 PM
philnshelb
philnshelb's Avatar
Default second screw headlight adjustment
Originally Posted by CJITTY
Yes, exactly..actually that rubber/plastic-ish cap moves and exposes what looks like a "gear". You put a phillips screwdriver head and turn which moves the gear..you have to pay close attention because each turn makes a difference. Get your car on a dark color wall and turn it a little to see which direction is up or down and then remember that. Now, the issue is you have to turn the 2nd gear the same way, it is in the far back corner and I recall it being a PITA to adjust..I think there are two screws for adjustment because of the AFS
Working on the drivers side I cant seem to find a similiar plug for the second adjustment.
Old 05-29-16, 11:49 AM
Dr. Jekyll
Dr. Jekyll's Avatar
I pulled all the covers and looked hard for the adjustment screw towards the front of the car that's supposed to adjust the light up but can't find it. Has anyone with a 13+ LS found the screw? If so I'd really appreciate the location.
keltonks
10-27-18 05:34 PM
gearheader
CT 200h Model (2011-2017)
06-19-18 12:50 PM
The G Man
GX - 1st Gen (2004-2009)
14
11-30-07 10:26 AM
mctuners
11-14-07 10:59 PM
Invisibleman
04-16-03 12:08 PM
Quick Reply: how to adjust headlight
