LS460 HID Fogs and ballast mounting questions
Old 10-16-10, 10:35 AM
CJITTY
CJITTY's Avatar
Default LS460 HID Fogs and ballast mounting questions
Been searching for a while and can't find any specifics or a DIY. I know they make a Japan HID projector HID setup, but I plan to just do the aftermarket HID kit since I have a set of ballasts already and just need a pair of 9006 style HID bulbs. I have installed these kits on other cars but haven't attempted on my 460.
For those who have installed aftermarket HID kits for their fogs, here are my questions:
1. Where did you mount the ballast on each side?
2. Is bumper removal required or just access via the fender liner?
3. Any excessive heat issues? especially if using 2500-3000K yellow HID bulbs?
4. Is there a vertical aim adjustment screw for the fog lamps?
5. Side note, can you change the Nike light via fender liner since I'll be working in that space anyway?
Thanks!
Old 10-16-10, 04:11 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
if you pull back the fender lining, you should be able to find plenty of spaces or other harnesses where you can zip ties the ballasts to. i don't think removing the bumper is needed. just turn the wheel one way and pull the lining back. most 2is and 3gs people do it that way. i haven't heard of any heat issues so far on those models. and hid are 35w so hopefully not too bad. color temperature on hid bulbs don't affect the heat output that much.
i am not sure if there is aim adjustment on the fogs, never looked into that
and to change the nike light, from my memory, i think you will need to remove the bumper. i can be wrong on this one though
Old 10-16-10, 06:38 PM
CJITTY
CJITTY's Avatar
Thanks, it looks like the fender liner is the easiest route, similar to how the GS folks do it...that stupid nike light is something I'll have to do at some point. after seeing some examples on how nice it would look with a pure white LED, I really want to do that too. I have HID fogs on my Acura TL and I can assure you that the basic ebay 3000K yellow HID bulbs put out more heat than the Philips 4100K do. I switched my TL's HID fogs back and forth yellow to white and vice versa a few times and there seems to be more heat being thrown out by the 3000K bulbs. I suspect because of the coating on the bulb glass to get the deep yellow color. I was concerned about the glare shield in the LS fogs, but I assume if they can handle 55 watt halogens, they should be able to handle the 35 watt HIDs. Can't wait to do this, the yellow looks really good on my TL.
As far as aiming the fogs, the 2nd Gen TL's have an adjustment that makes it easy. when you put the HIDs in, they have to be aimed down because they are mad bright..the lenses do a good job of putting light where it needs to go with a nice cutoff, just hope the LS fog optics will do the same
Old 10-16-10, 11:47 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
yup, i had a 02 tls before as well so i know about the fog aim adjustment. but on the ls460, i don't know. i can tell you on my old gs400 and is300 (and i believe sc430 as well), i didn't see any aim adjustment. i had hid fogs on the tls as well, 4 "headlights", that was a pretty neat idea
Old 10-17-10, 11:23 PM
melymel96
melymel96's Avatar
Hi Henry. yes you're right about the Nike lights...the bumper has to be removed. Last time I took my car to Newport for service they had to take the bumper off so they installed them for me. I got some LED's from Japan. I'll post some pics tomorrow when I get back from San Francisco.
melymel96
melymel96's Avatar
By the way I'd like to get some HID fogs as well. Dont really see myself spending 1900 for the kit out of Japan so I look forward to see how this comes out.
Old 10-17-10, 11:48 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
tony, you have leds on the nike lights? darn, i should have taken a look last time when we met!!!!!
Old 10-18-10, 08:21 AM
melymel96
melymel96's Avatar
Yeah they really make a huge difference. I want the NAV overide so we will meet up again! lol You really need the nav overide with the ipod integration. Scrolling is a pain lol.
Thanks Henry.
Old 10-18-10, 10:13 AM
CJITTY
CJITTY's Avatar
I wish I could afford the real deal HID projector setup like Japan, but my kit will cost me $35 with bulbs and ballasts. Used this ebay seller for a couple years and they work great! So, $35 kit with stock non projector fog lenses it is
Old 10-18-10, 10:16 AM
CJITTY
CJITTY's Avatar
I can't wait to see these pics of the Nike light..it seems like the brighter the bulb, the farther it glows into the nike shape or is that just an illusion I am seeing on some of the pics I have seen here on CL? Either way, hyper white 4300K LEDs look better than the dull **** color our nike lights have now
Old 10-18-10, 08:22 PM
melymel96
melymel96's Avatar
Here you go...going to open another post with more pics....
Old 10-19-10, 06:09 AM
CJITTY
CJITTY's Avatar
^^^Thats real tight right there!
Old 10-19-10, 07:50 AM
virotek
virotek's Avatar
I think I saw an adjustment screw for the foglights when I had the bumper off.
Old 10-20-10, 03:30 PM
RocketSlug
RocketSlug's Avatar
Default What bulb for Nike lights?
Yes! I must replace those. What number bulb? 194?
Old 01-09-11, 01:33 PM
MeTrO
MeTrO's Avatar
Sorry to dig up the old thread....what bulb number are the nike lights, AND do you have to take the bumper off to change them?
Thank you.
Chad
wpbmed
ES - 5th Gen (2007-2012)
09-09-12 03:20 PM
Ramon
02-10-12 04:32 PM
blkis_250
CL of Hawaii
16
04-15-10 06:24 PM
D-MAN63
09-18-06 11:52 PM
nhidog
09-05-06 11:19 AM
Quick Reply: LS460 HID Fogs and ballast mounting questions
