Fog Light Replacement
Does anybody know how to replace the fog lights. I bought an aftermarket set of 9006 lights that are more white than the existing horrific yellowish lights. I have seen previous posts as far as the type of bulbs, etc...but I just need to know logistically how to get to the existing ones to replace them. I know the headlight bulbs require taking off the wheels and fender well. Do the fog lights require that or do you go thru the engine cover, etc? The manual I have is pretty vague... If anybody can help I would be most greatful. Thanks !
very simple.
turn your wheels all the way to the opposite side, take a flat head screwdriver and turn your wheel well screw about 180 degrees, its the one on the edge of the fender, there is only one on the front. then gentley pry it out, its plastic so dont break it.
Then just push the inner liner towards the inside of the well and you will see you now have a little access to get at the back of the fog lamps, they are a turn to get out and disconnect and put the new ones in. First time maybe 15 min a side, after that about 5 min for both, its really easy once you understand how to do it.
