dumb question (460 vs. 460L size)
Old 12-10-07, 07:01 PM
ironhorse
ironhorse's Avatar
Default dumb question (460 vs. 460L size)
How much bigger is the Ls 460L then the 460, someone asked and I had no idea.
Thanks
Old 12-10-07, 07:08 PM
encore888
encore888's Avatar
It's not a dumb question IMO, it's a valid one. Looking at the specs:
http://www.lexus.com/models/LS/detai...ions.html?id=0
LS 460
Code:
Length (in / mm)  	198.0 / 5,029
Width (in / mm) 	73.8 / 1,875
Height (in / mm) 	58.1 / 1,476
Wheelbase (in / mm) 	116.9 / 2,969
Curb Weight (lb / kg) 	4,244 / 1,925
Headroom, Front (in / mm) 	38.0 / 965
Headroom, Rear (in / mm) 	38.0 / 965
Shoulder Room, Front (in / mm) 	58.5 / 1,486
Shoulder Room, Rear (in / mm) 	56.9 / 1,445
Hip Room, Front (in / mm) 	55.4 / 1,407
Hip Room, Rear (in / mm) 	55.5 / 1,410
Trunk Capacity (cu ft/ L) 	18.0 / 509
LS 460 L
Code:
Length (in / mm)  	202.8 / 5,151
Ht., AVS (in / mm) 	57.7 / 1,465
Wheelbase (in / mm) 	121.7 / 3,091
Curb Weight (lb / kg) 	4,332 / 1,965
Shoulder Room, Front (in / mm) 	58.5 / 1,485
Shoulder Room, Rear (in / mm) 	56.4 / 1,433
Trunk Capacity (cu ft / L) 	18.0 / 509
Trunk Capacity (cu ft / L)   	14.1 / 399 (Rear-Seat Upgrade Package or Exec Package)
Trunk Capacity (cu ft / L) 	12.0 / 339 (Rear-Seat Upgrade Package or Exec Package)
The LS 460 L is approximately 5 inches longer overall. They don't give exact legroom figures I guess because it depends on how far the front seats are moved forward or back.
Old 12-10-07, 07:11 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
correct, almost 5 inches. and just in case, all those 5 inches go to the back seat space. that's why the rear doors are larger, and also why you see pretty much the same increase in wheel base increase
Old 12-10-07, 07:27 PM
Gojirra99
Super Moderator
Senior Moderator
Gojirra99's Avatar
Originally Posted by encore888
LS 460 L
Code:
I don't quite get this, which one is it ?
Old 12-10-07, 10:31 PM
Nextourer
Nextourer's Avatar
I think one's with the rear cooler box
Old 12-10-07, 11:19 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
indeed, i know about the 12 cu ft setup, no idea on the 14?
Old 12-11-07, 12:45 AM
Johnny
Johnny's Avatar
That's a 2.1 cu/ft difference; that box's just a tiny six pack holder.
On the other hand, there's ducting associated with it, so you may have a point there.
Old 12-11-07, 06:43 AM
Gojirra99
Super Moderator
Senior Moderator
Gojirra99's Avatar
It could be the ducting, but the rear cooler is standard for the Exec. Package (at least for Canadian specs), the way they put it above, it's as if you can opt out of the cooler box, & you can get a cooler box for the 5-seater with just the rear-seat upgrade . . .
Old 12-11-07, 07:08 AM
RXSF
Forum Moderator
RXSF's Avatar
i believe its 14 cu ft when you have the rear seat upgrade and 12 with the executive.
Old 12-11-07, 09:22 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
agree, seems like an option that doesn't exist
RXSF, maybe we need cars side by side, but several times i looked at my car and the exec package, the trunk seems the same. and in the spec is says rear seats upgrade OR exec package, that makes things even more confusing
Old 12-11-07, 08:09 PM
Nextourer
Nextourer's Avatar
RXSF's post sent a light bulb off.
MAYBE.... the rear seat upgrade is the one with the power rear seats with memory and cool box. The Exec is the power rear seats with the ottoman and cool box
Old 12-11-07, 08:52 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
that's right, i have the rear seats upgrade. however, it says
both lines say the same except the capacity.
Old 12-11-07, 10:12 PM
Nextourer
Nextourer's Avatar
dang, so much for my "Eureka" moment.
Old 12-11-07, 11:56 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
lol, it's cool, believe me i want to find out the difference too. i guess i would be "that much" happier if i know my trunk is 2 cu ft larger than that of andrew's car
Old 12-12-07, 08:11 AM
astrotoy
astrotoy's Avatar
My exec seat has the (very) small trunk. I think my Civic Hybrid has a larger trunk. Of course, the back seat is so large it can fit suitcases on the floor and on the seat at the same time. Just don't pick up three passengers with three big suitcases at the same time. LT
Quick Reply: dumb question (460 vs. 460L size)
