Reset AFS light after suspension change
Recently put coilover on my 460. While doing it, we had to move the arms and disconnect the sensor. As to be expected I now have the AFS light flashing.
Dealer wants $125 to plug it in to reset it which is ridiculous. There's nothing wrong with the system or components. Just needs reset. Did anyone ever work out how to reset it? Do any OBD scanners or Carista do it? Thanks,
jonny
jonny
The Carista app can reset your fault codes, but if the level of the suspension is such that it constantly causes AFS fault codes, then that would be no help. So I'm not sure on this one. If you just temporarily disconnected a sensor and now it's sending its proper signal again, it should just be a matter of resetting fault codes and Carista should be able to do it.
