Current 430 owner shopping for a 460L
Hi all, we have an 06 ML with 61k miles. Bought it with 48k miles in April 2016. I enjoy the car very much but deep down I always wanted a 460L.
Test drove an 08 today with 141k miles. It drove better than I expected on the 19" rims. Everything works (lights, heated/cooled seats, seat adjustments, and various controls, keyless entry, etc.). This is from a small independent dealership that sources their cars from Carmax auctions. I've always had reservations about places like these but couldn't resist checking the car out. I will have my mechanic inspect the car too. Until then, here are my immediate observations/concerns. Can anyone help chime in on the items below, please?
1. I need to run the VIN through Lexus site and Carfax (no guarantees it'll report everything).
2. The driver's side rear speaker seems really dingy compared to passenger side. Hopefully they can clean it or replace it.
3. Is there something important that goes here or is it just a cover? Why would someone remove it?
4. The dash brightness doesn't appear to change when I press these buttons. Is there a special way of using the adjustments?
5. The dash also shows low tire pressure and to check the rear lights. Odd since the rear lights looked fine. The salesperson also had to jumpstart the car because the battery was dead. Nav maps also original 2007. Not really any major issues that I can see. Leather also looked in great shape with barely a wrinkle:
6. Yes, the 08 isn't as quiet at idle as our 430. The biggest question mark I have is why the 08 is so loud when gently accelerating during the test drive. It just sounded very metallic and chain-like. Couldn't find any examples on YouTube of what a 460 engine properly sounds like from the cabin when accelerating. Need to test drive a few others to get a better baseline. The shift quality of the 8-speed seemed fine. Not great but not bad -- certainly didn't do anything that I found distracting or worrisome. Not sure if it's normal but I notice the car really slows down when you let off the gas, as if it had regenerative brakes but this isn't a hybrid.
I have to say..unless these seats are brand new, they look fantastic!
These cars really age well when they are taken care of.
Regarding the dirty area in the rear by the c-pillar/speaker, that could very well be where a mechanic pulled the seat away from the rear decking of the vehicle to perform a repair of some sort... Or perhaps where a child like to place their hands..you don't really know. But as long as when you play music and it works, some Sonax and a moist/damp mf cloth or Woolite and a damp mf cloth and blotting/gentle wipes will bring it clean.
The second item is the shift lock cover.
I wouldn't say its something imperative, however, there is normally a small plastic piece/cover there with a slit in it the size/width of a key that you would use in the event the gears were to lock up, or switch gears with the ignition off. It'd be good to have the cover, but its such a small space, I doubt anything would go in there by mistake, BUT it'd be best covered up to avoid any mishaps.
TPMS sensors could be faulty/battery dying or the wheels could actually need air.
Regarding he message to check rear lights-I've never heard/seen that before.
If its been sitting for a while, especially in the cold, it would need to be jump started, or it could actually need a new battery. have that tested as well.
Maps, if you care, will need an update but it'll only be to what the software will handle, which I think is up to 2010. Im not sure it can be obtained elsewhere, but the dealership asks from $180-$220 I believe. The update will also flash and continue past the start-up screen where you have to press/touch "I Agree" in order for the screen to resume normal functionality.
Those brightness buttons should work... Its not an over all huge difference, but you should be able to tell a difference in brightness.
Those rotors looks horrible but could actually be ok, as the longer a car sits, surface rust will appear and as the car drives and brakes, the friction between the pads and rotors will clean them up a bit.
Your mechanic will better gauge the rotor and pad thickness/condition.
As others will tell you/have said, the 460 isn't a dead silent operator, as you will and do hear lifter noise from DI, but it also appears some vehicles are louder than others.
My advice to you is what others told me and it seems as if you have the right idea already, is to test drive multiple specimens to obtain a solid idea as to what an older LS should sound like.
Shifting; im wondering if the trans fluid has been changed...
Im sure many others will chime in, but I hope ive provided some input here.
Keep us posted and good luck!!
I forgot one other item. The rubber handle part under the trunk doesn't appear to do anything. I can't seem to manually open the trunk with this handle. Is there a button under the rubber? The trunk seems to only open, and automatically lift up, from the interior trunk release or the keyfob:
Thanks a lot for the assessment, CRowe. Greatly appreciate it. In the process of coordinating a Pre-purchase inspection with my mechanic. We have a great relationship so he's only charging me $70 for a 2-hour inspection. He knows we're also in the market for an 07 or 08 RX350 that will need his thorough inspection.
When I was shopping for mine I had quite a few questions to ask and everyone was very, very helpful.
This forum is really an awesome place for information and some fantastic people.
Ironic you mention this and I should also thank you for this question, as I had also wondered the same thing and have always meant to ask but always seem to forget.
When I press that same button, nothing happens for me either, but I do know that same button can become deteriorated and sticky to the point its absolutely useless, so be careful.
Oh, also...those tires have to go! Cinturato A/S+ is the route to go!!
Not a problem, only trying to help!
Good observations and it helps to do your homework before you purchase it.
Thank you, comotiger, and good point. I expected the button to work like our 430 (which also requires the key fob to be in close proximity) and I can't recall if I was holding the key fob or if the salesperson had it on his body and maybe was standing a little too far. I will try to retest and make sure the next time I see the car.
Your rear light and braking problems may be related. Is it possible that the brake is always engaged at a low level, like some folks who rest one foot on the brake pedal and the other on the gas? In your case, something may be continuously engaging the brake. Ask someone else to drive while you check the brake lights and center stop light.
Thanks, comotiger! Glad to hear you and your family are loving your '14 LWB.
I will do as you suggested and look into Autocheck too. I don't think the 08 I'm looking at is UL. The rear console doesn't have the assortment of controls and buttons, yet the B-pillar has vents. I thought B-pillar vents only appeared if there is the separate rear-AC unit in the trunk and if the rear center console had the display and extra buttons. The trunk doesnt appear to have a second AC condenser unit encroaching on space, so I'm not sure why this model has B-pillar vents. Plus, this one is without the air suspension (which I prefer).
I am pretty sure yours is an UL. Or maybe it is the Comfort Plus package in pre-2010 cars.
1) You have seat memory buttons on the rear doors. The three buttons on the center console control the seat reclining functions for the L and R rear seats.
2) In these older models, the massaging control buttons were placed on "remote control" units found inside the center console. Maybe you have those, I don't know. Likewise, the seat cool/heat buttons are also underneath the leather panel.
I just found these pictures on the web, and matches your car nicely.
The B-pillar vents are found on all LS460s. Do you have AC vents above the rear passenger doors? That would be a sign of the rear AC unit. Plus you would have a cool box. I think these features were added in 2010 and called the UltraLux. Maybe there was only Comfort Plus and no UltraLux before 2010. Just a guess. Regardless, this car looks great. Hope you get a great deal!
Oh, I didn't know all 460s had the B-pillar vents! Thanks for setting me straight, comotiger. I definitely have some of my packages mixed up. I assumed Ultra Luxury meant it had every possible option available. I do not believe the 08 I'm looking at has vents in the headliner. I definitely would have noticed those. And thank you for reminding me about the rear memory seats. This will actually allow some sort of limited recline adjustment while the car seat blocks the rear center armrest!
The 08 definitely doesn't have the cooler box. I checked and it's just a pass-through.
The rear seat memory buttons on the doors does not give you any ability to adjust the seats. It merely allows the seats to return to a position entered into memory.
