control arm bushings, tie rods, wheel bearings, struts, shocks, shock absorber
Old 09-28-16, 12:47 PM
2v1g
2v1g's Avatar
Default control arm bushings, tie rods, wheel bearings, struts, shocks, shock absorber
My LS430 changed rear shock absorber, my LS460 rear struts are leaking, I saw a thread saying rear have only shocks, no struts. I am a little confused. Is there a pic that can show where are control arm bushings, tie rods, wheel bearings, struts, shocks, shock absorber in Lexus LS suspension?
Old 09-28-16, 05:19 PM
superdenso
superdenso's Avatar
Are you going for the complete suspension service? You can search for Lexus of south atlanta. They have diagrams and imo decent pricing.
Old 09-29-16, 08:53 AM
roadfrog
roadfrog's Avatar
Google Images has tons of diagrams and schematics. Use search terms,"LS460 rear suspension diagram".
Old 11-11-16, 07:14 PM
2v1g
2v1g's Avatar
This week I complained to the dealer that my wife's RX350 have a stiff ride and I can feel every road inperfection. They checked and find both right rear shock and right front strut are leaked out. 3rd party warranty doesn't cover struts & shocks, so I have to pay myself.
Is shock and strut the same?
Why front shock cost way more than the rear shock (front $180, rear $50)?
Why the labor to replace the front shock is way more than rear one(front $282 vs rear $122)?
anytime you replace shocks, do you need to do wheel alignment?
Old 11-12-16, 04:42 AM
Doublebase
Doublebase's Avatar
A strut is a shock and spring together as a unit. A shock and a strut are not the same thing; there are still suspension systems on the road that set up the rear suspension with a shock and spring next to it....not together as a single unit, but separate. The RX 350 probably doesn't have this older type of setup, but a strut can be taken apart and they can replace just the shock portion of the unit...which is probably where they're getting the $50 price tag. Also rear suspension components are sometimes cheaper because they are not as large as front suspension parts, because front suspensions have to also support the weight of the engine and transmission.
Old 11-12-16, 12:57 PM
2v1g
2v1g's Avatar
front strut I replaced: 48510-8Z073
rear shock I replace: 48531-0E131
front struts
rear shock
Old 11-12-16, 12:58 PM
2v1g
2v1g's Avatar
I guess struts in LS cost even more than RX
babbles
HS 250h Model (2010-2012)
12-02-18 03:33 PM
peterls
13
06-09-14 02:40 AM
handzilla
Suspension and Brakes
17
03-12-12 05:40 AM
handoverfi
01-24-11 02:51 PM
Jmai22
07-29-02 10:55 AM
Quick Reply: control arm bushings, tie rods, wheel bearings, struts, shocks, shock absorber
