Wheels
Old 07-07-16, 06:11 AM
twin703
twin703's Avatar
Default Wheels
Help....I dont want to lift or lower my ride but I dont want rub and the less amount of wheel gap possible what tire size and offset should I go with? 2007 ls460 rwd im going with 22 inch keep that in mind with any suggestions ? Also do bmw 7 series rims fit the ls460 ?
Saw a lady on here once with 24's anyone else here running 24s ???
Old 07-07-16, 09:00 AM
GR6RR
GR6RR's Avatar
https://www.clublexus.com/forums/ls-...ls-thread.html
Old 07-07-16, 10:04 PM
Lextrician
Lextrician's Avatar
i help you out a lil bit but the sticky has all the wheel info. bmw wheels fit but the rears will be aggressive and the fronts will poke out a lil bit so you will rub if you are running stock suspension, mainly the rears if you have passengers. a rear wheel well shave will help you out but its not hundred percent unless you have your wheel specs.. look at the wheel and tire sticky.
Old 07-08-16, 06:53 PM
superdenso
superdenso's Avatar
Due to the road conditions in the DC area, consider the following:
Northern VA----->20's
below Stafford-->22's
Further, a huge pothole in the middle of the highway on 95S near Richmond bent the 3pc GFG19s on my SL5 Benz. The VaDOT sent a "Sorry Charlie" letter/I was not impressed
CJITTY
05-18-22 03:38 AM
Tantrix
05-28-20 06:12 AM
jbkhat303
09-07-14 06:03 PM
Jmonsini57
10-25-13 06:50 AM
CJITTY
12-31-12 05:07 AM
Quick Reply: Wheels
