HELP! 2007 LS 460 Crankshaft Position Sensor
Old 01-03-16, 09:50 AM
louisindal
louisindal's Avatar
Default HELP! 2007 LS 460 Crankshaft Position Sensor
Car is stuck in the garage. Code P0335 - crankshaft position sensor. Where can i find the actual location to replace. Any youtube or photos?
Thanks
Louis
Old 01-03-16, 10:04 AM
roadfrog
roadfrog's Avatar
Well, the good news is it's easy to access. It's located under the engine. You have to remove the plastic panel underneath the car and it's basically, "right there". There's a harness attached to it and one bolt holding it in place. Labor is quoted as less than an hour and Lexus charges about 100 bucks for the part. I see them selling on Ebay for 22 bucks free shipping. Here's a pic of it and the repair procedure:
http://www.ebay.com/itm/New-Engine-C...hVcAqI&vxp=mtr
Old 01-03-16, 10:08 AM
Doublebase
Doublebase's Avatar
Awesome post roadfrog, and if Lexus gets around $100 for the part and eBay prices are $22...then perhaps at a parts store they are somewhere around $50...that will be a quicker solutions if the guy is stuck and needs the car.
Old 01-03-16, 10:14 AM
roadfrog
roadfrog's Avatar
True....50 bucks would be worth getting on the road sooner. I forgot he's stranded. Even Lexus' 100 dollars is not breaking the bank.
Old 01-03-16, 10:16 AM
Doublebase
Doublebase's Avatar
Yeah $100 doesn't seem bad for a sensor like that...kind of surprising when they're charging $350 bucks for a single control arm.
CamelKool (10-23-20)
Old 01-03-16, 11:00 AM
louisindal
louisindal's Avatar
Default drivers side or passenger
drivers side?
Old 01-03-16, 01:26 PM
louisindal
louisindal's Avatar
Default HELP> Stuck
replaced crankshaft sensor on 2007 LS460. still won't start. Push Start button and get a single clicck. Any advice will be much appreciated.
Thanks
Louis
Old 01-03-16, 02:37 PM
Kbueno
Kbueno's Avatar
Possibly Starter?
Old 01-03-16, 04:12 PM
Doublebase
Doublebase's Avatar
Same thing happened to me, it was the battery.
Old 01-03-16, 04:24 PM
louisindal
louisindal's Avatar
Default battery was replaced
battery was replaced.
and thanks roadfrog as I did get the sensor replaced. There was a metal shield that had to be removed.
Thanks all but still no start, just a single clicck
Old 01-03-16, 04:26 PM
tlk2megoos
tlk2megoos's Avatar
This is worth looking at. Weak batteries cause many strange electrical gremlins. If it's an old battery, it could cause these kind of problems even though it tests fine.
Old 01-03-16, 04:40 PM
Doublebase
Doublebase's Avatar
Is it fully charged? I mean fully, because if it's even slightly weak...slightly drained...it won't start.
Old 01-03-16, 07:32 PM
louisindal
louisindal's Avatar
Brand new battery.... manufactured 12/2015
Old 01-03-16, 08:37 PM
roadfrog
roadfrog's Avatar
Will it start with booster cables? Was something left on to drain the battery? If you insist that it's not the battery, then that only leaves a bad starter or a bad ground/electrical connection. I'm with the others here though....bad or drained battery.
Old 01-03-16, 10:05 PM
aaauae
aaauae's Avatar
Definately starter , i had same issue some months back .
Push start button and all you hear is click
Replace starter and you are good to go
Quick Reply: HELP! 2007 LS 460 Crankshaft Position Sensor
