Gps signal loss.
Gps signal loss.
I have a very very strange problem. My car hasn't had the gps icon on for about a week. I've also had gps problems with my phone. I downloaded a utility on my phone that tells me how many gps satellites I'm connected to. When my car is off with the windows up and sunroof closed I'm connected to 10 to 15 atennas. When the car is on it drops to zero. I stick my phone out the window and it goes back up the 10 to 15. Also when I turn the car off it goes up to 10 to 15. Anyone else have an issue like this?
What type of window tint do you have? Some metallic films can block signals. I had an issue with my nav GPS icon but it was a loose connection and it was fixed. Do you have any type of plug n play devices inline with your head unit and nav? Are you sure your GPS antenna is plugged in all the way on back of nav screen. I heard it can look ad if its plugged in but can be pushed further and properly shielded and connected. With dash work, that connection can get loose.
I've had issues last week with my phone and Waze app not seeing GPS. Intermittent though. Could be major solar flares disrupting GPS also but haven't heard that on the news. I think its a combo of loose connection combined with electrical interference...pop that nav screen out and make sure your GPS connection is secured.
The GPS constellation is composed of about 24 satellites flying at an altitude of about 12,000 miles (half-synchronous). It would only be possible for a terrestrial receiver to see about 6 of them at any one time.
One thing you need to consider is an interfering signal from something that you have added to your car. So, be sure to turn off or disconnect radar detectors, power converters, laptop computers, cell phones - all things electronic that are not an OEM part of your car. You need to also consider that someone has added a GPS jamming device to your car. And you need to check for a tracking device that may have been added.
Your car's GPS antenna is located in the dash below the rearview mirror so windows and sunroof have nothing to do with it.
The advice you were given about a loose antenna connection may be spot on. Sometimes receivers will oscillate when they don't have a good match to their antenna. The antenna or cable may be defective or the cable connection may be loose.
You can see from the diagnostic screen that only 6 satellites (23,9,7, 16,20 & 10) have elevation angles and signal levels sufficient to provide useful information. The other 5 have shallow elevation angles and attendant low signal levels and would not be usable for "fixing" data. The GPS orbital path design only guarantees 4 usable satellites any where on Earth.
Sent from my iPhone using IB AutoGroup
Ok bro....I tried to help. My solution was pushing in the loose connector to the back of the Nav. My solution for weak cell phone gps was a $5 Walgreens vent cell phone holder. Phone sits perfect to connect to cig plug and clear view of sky for GPS receiver. Waze locks in instantly. Depending on which direction I travel impacts gps strength too. Going north is weaker than south..makes sense since satellites follow equator. With my loose connection fix, car gps is never a problem and my GPS icon comes on right away and not spotty or randomly displays when I had the issue back then
Here is a neat graphic that I found that shows the orbital paths in mass. You can see that for the reference point of 45 deg N there are at least 6 satellites always visible.
http://en.wikipedia.org/wiki/Global_...llationGPS.gif
The launch inclination of the GPS satellites is about 55 deg, so they are not following the equator. Here is a neat graphic that I found that shows the orbital paths in mass. You can see that for the reference point of 45 deg N there are at least 6 satellites always visible. http://en.wikipedia.org/wiki/Global_...llationGPS.gif
