for those on Accuair / E level please come in !!
ok guys i need some help mounting my e level sensors im not sure where they should go i see provisions on the control arms for the headlights but i dont know where and how the sensors should be mounted ... any help and PICS are appreciated ...
I think because if you use the search feature you'd find the topic discussed. there's also a thread for this exact question in the special interests section/vip section. you generally get good response to questions asked unless it's been discussed. you'll also find pictures
https://www.clublexus.com/forums/vip...-installs.html
Mines were mounted to the front lower control arms but i have to relocate them due to the new arms being installed. The original arms had a bolt that would hold the speed sensor line and another line that i don't know what it is right now but the new control arms don't have that bolt. So now i need to figure out where to remount the arms.
i think posting up pics is not really going to help each individual as far as how to mount them.
because each person's air strut travel is different. thus mounting it the same way it may or may not have the perfect 2.75" travel the sensor need.
plus there are other factor such as wheel clearance too. work on stock wheels may not work on aftermarket.
you really don't want those sensor to move too little where is not accurate or move too much where you can break them.
those sensor need to be clear of everything in under all conditions.
if you understand fully how they work, you don't really need pics you should be able to figure it all out on your own.
thanks man im trying to get to the nitty gritty of this suspension ordeal its not as easy as people say and there is NO instructions only with the accuair stuff soo i have a ton of $ in parts that i need to figuer out myself and or ask people that have done the install them selves most people take it to a shop and say here install this lol
