I'm really disappointed and I want the world to know it...
I'll be posting a link to this discussion on Twitter for extra exposure. I'm sure nobody at Lexus cares - but maybe if other people are as disappointed as I am - maybe they'll consider either making changes - or giving us a solution to this problem.
I know I posted about this one other time - but it deserves a new thread. I am very, very, very disappointed with the Mark Levinson stereo system in my 2012 Lexus LS460L.
I swear I'm not just saying this but one of the MAIN reasons I traded in my 2008 Lexus LS460L for a brand new one is the stereo system.
Yes. I like the soft, quiet ride. Yes, I like the luxury features. And, yes - I like the interior/exterior appearance. Amongst those favorites is the stereo system. How on EARTH can this piece of garbage be so damned quiet?! How was the sound system in my 2008 SO MUCH LOUDER?! I can't STAND it.
I swear I will not buy another LS if something isn't done about this. I have this EXTRAORDINARY sound system - but it doesn't go loud. And I know what you're thinking - it DOES go loud. NOT TO ME. With my 2008, Satellite/FM/CD - they were all the same volume. With my 2012, FM and CD are loud as well. Satellite, USB and Bluetooth are extremely low. I never use FM or CD...
I know this is a setting intentionally made by Lexus. All it takes is some programming to fix it. I don't know why I need a NANNY to LIMIT MY VOLUME.
Very Displeased...and a little bit insulted.
Are you sure your dynamic volume control is switched off? Also, did you put the EQ settings where you want them to be? Turn the surround ON for 5.1 DVDs - makes a big difference. Even using stereo CDs the surround yields some improvement. Make sure the balance is correct as well, both left/right and front/back. Unless you have a blown amp, your sound should be as loud as '07 and '08 models.
I was very satisfied with the Mark Levinson system in my 2008. I know you can get better but it was good enough.
I've tried everything but next time I'm in the car, I'll check to make sure the dynamic volume control is off. EQ settings are set for each output type. All other settings are perfect. I'm kind of an audio nut so I take care of all this stuff right away.
I know the amp is okay because the sound system is as loud as my 2008 using FM stereo or CD. So the power is there - it's just nannied for Satellite, Bluetooth and USB.
Yes, I have the settings about the same for everything - FM, CD, Bluetooth, Satellite, USB, yada, yada, yada.
So you guys aren't noticing a difference? Last time I wrote something about this, people agreed with me like it was common knowledge. In fact, there's even a hack out there (on YouTube) to bring your volume back to normal on the Bluetooth setting. I'm assuming this same setting can be altered for Satellite and USB - just nobody knows how to do it yet...
Sal, Call the Lexus customer satisfaction line. I will PM you the name of the rep to ask for. She knows this problem well as she has been dealing with me for 3+ months. I proved to them that the 2012 has a problem with the bass, their field engineer has proof of it. I measured the sound levels and frequencies using an RTA analyzer on an iPhone. They know that it sounds different, and that it doesn't play as loud, but they don't have a solution.
I and many others had to have their amps replaced under warranty with the 2007-2009 ML System. I suspect Lexus put a "governor" on the volume to prevent blowing and replacing so many amps under warranty.
I doubt Lexus will increase the allowed volume in the future.
It seems ML, who developed the system for Lexus, has yet to resolve this issue since so many others are so satisfied with the sound quality at lower levels.
Nothing's perfect...only the Pursuit of Perfection
It is amazing how different the pre 2010 Levinson models sound compared to the newer. I was shocked..I used a dvd audio cd to compare. But..the system can be upgraded..talk to shibumi1 or search his threads
Jlawr, do bluetooth audio and USB work on your car with the 2007 - 2009 amp? May I ask which dealer you went to to have the amp replaced? My dealer is willing to help, but neither they nor the Lexus field tech were sure if replacing the amp would help. The Lexus engineering team in the US was going to check with the team in Japan to find out what changed.
Has anyone successfully put an aftermarket subwoofer on an ML system? I know a few have done it on the premium system with excellent results. The ML system is a 12 channel amp and Lexus appears to be rolling off the lower frequencies as you raise the volume. As such there is no easy way to get a good signal for an aftermarket amp and sub.
Maybe I'm lucky (?) but my LS ML system will make the rear view mirror vibrate when it's cranked up. It's quite similar to the ML in the GX460 in that respect.
The LS460L is already an incomplete package (for ME) with it's lackluster performance. Now there's another glaring issue and that removes the LS from my short list next year.
