Outside rear view mirror jiggle
Old 02-03-11, 08:34 PM
byroncat
byroncat's Avatar
Smile Outside rear view mirror jiggle
Recently I noticed a jiggle in my outside mirror while washing my 2007 LS 460
I mentioned it to the service writter @ Lexus to see if it could be tightened;I was susprised to hear there is a TBIS on this issue which will be covered under warranty.
I am currently waiting for the arrival of a "bolt pack" to make the repairB]
Old 02-04-11, 06:14 AM
randomwalk
randomwalk's Avatar
mine was the same...can't fix it..the whole thing was replaced under warranty.
Old 02-04-11, 10:53 AM
blackz405
blackz405's Avatar
I have the same problem on the passenger side. My 07 is out of warranty so I need to fix it myself. Do I have to replace the "whole" mirror housing? Can someone post the TSB?
Old 02-04-11, 10:56 AM
randomwalk
randomwalk's Avatar
yes..there are no adjustment (so I was told).
Old 02-06-11, 08:12 PM
byroncat
byroncat's Avatar
The TSB # is L-SB-0033-10.
This TSB is effective for 2007-2009 LS 460's
The dealer now has my bolt kit;they will install it as soon as I can make time for it.
FYI it looks like they must remove the entire mirror to make the repair-- I'm glad it is covered by warranty.
Byroncat
Old 02-06-11, 08:13 PM
byroncat
byroncat's Avatar
hope this helps.
Old 02-13-11, 12:16 PM
marylandlp
marylandlp's Avatar
Default loose mirror-tsib--lsb-0033-10
I tried to find the tsb you referenced in your posting.A google search identified a 0033-08 bulletin which addressed problems with the engine pulleys,but not loose mirrors.Have i missed something? tx
Old 02-13-11, 11:41 PM
I8ABMR
I8ABMR's Avatar
If they cant fix the juggle they can replace the entire mirror assembly
Old 02-15-11, 07:42 PM
byroncat
byroncat's Avatar
Smile
Alldata says the TSB # is L-SB-0033-10.
I just had mine fixed under warranty I think it cost Lexus about $100.
The mirror is now solid.
Byroncat
Old 02-15-11, 07:48 PM
byroncat
byroncat's Avatar
Not sure about the problem with the # but alldata says the TSB # is L-SB-0033-10.
The dealer fixed mine today; it appears to be solid.
They should know of the problem and the fix.
Byroncat
toptech
10-26-11 08:58 PM
bigblack06
08-15-11 07:02 AM
Numbahz
04-05-11 01:38 PM
caymandive
05-30-07 01:46 PM
Jim Rohr
04-28-06 11:47 AM
Quick Reply: Outside rear view mirror jiggle
