2004 LS 430 No start
Was there any change in the car from when it ran? Was the change sudden or did it get progressively harder to start or running and starting fine one minute and not starting the next?
Check relatively simple obvious stuff first - New gas, oil change, and parts, or maintenance changes of any kind? Is the chip in the key being recognized?
You will need to read error codes being produced to make a real diagnosis if nothing obvious is causing the issue.
Air, fuel, spark - that's it to run. Simple concept but sometimes tough to track down the culprit. Does the starter sound normal? I've had an issue in the past on an ES where the starter would spin but not actually do anything, new starter fixed the problem.
Wow. I learned something today! Pretty crazy the battery would have enough power to work the starter and turn the engine over, yet not enough spark!?
How did you come to the conclusion of the battery? Did you hook up jumper cables or something similar or arbitrarily changed the battery and she now runs??
91ls400own
04-15-16 03:24 AM
blkstealthpaid4
06-06-14 06:32 AM
