Adjustable toe arm question
I'm finally back in a lexus!! However, i had an issue with my ls430 that will be uploaded later. Short story i ended up buying megan racing toe arms. they are fully length adjustable. My question is; do i still need to use the stock cam bolts? Can I use a barreled center grade 9 or 10 standard bolt instead?
No, My brother has a friend who works at a lexus service center and got the bolts i needed. I had a rotted subframe where the flange mount broke off and the originaltoe adjusters were frozen (rust) to the original toe arms. I only replaced the toe arms and will honestly be doing the others asap!
