abs issue after wheel bearing replacement.
Old 01-03-17, 01:56 AM
svlexus
svlexus's Avatar
Default abs issue after wheel bearing replacement.
I replaced a rear wheel bearing, big pain in the butt with all the sledgehammering required. I got it all together, but now when Im pulling into a parking space and turning right, or backing up and turning right while hitting the brake, the abs seems to go off. I can hear the rumble and the pedal goes down a bit.
My best guess is that the abs sensor cover isnt quit in the right spot. Does that make sense?
Old 01-03-17, 06:53 AM
rkw77080
rkw77080's Avatar
The ABS looks for a "locked" wheel by monitoring the wheel speed sensors. It modulates the braking on the wheel that is turning significantly slower than the others to "anti-lock" the skidding brake/wheel. The ABS is not activated if the car is going slower than 10 km/hour (6 MPH). Are you getting any DTC error codes?
Old 01-03-17, 07:00 AM
Johnhav430
Johnhav430's Avatar
Just curious, doesn't our tire pressure work off abs, and would that imply that if under 6 mph, the car would not know there's a flat? Because quite often, a flat happens slowly, and it's discovered after sitting, and it would be ideal not to move the car on a flat....
Old 01-03-17, 08:21 AM
rkw77080
rkw77080's Avatar
I don't remember having to use the hammer on my rear wheel bearing replacement (see link below)
https://www.clublexus.com/forums/ls-...del-ls430.html
Can you share your experience on what others should watch out for?
Old 01-03-17, 10:05 AM
Gronemus
Gronemus's Avatar
I've never performed a wheel bearing replacement on my Lexus but I have done about a half dozen of them on other makes over the last ten years or so. Due to the rust issues that you typically see around here I generally had to sledge the old ones in order to get them off of the car and follow that up with a good amount of grinding to clean up the area before installing the new bearing. I always envy you folks down in the Southern region of the country when it comes time to do any under body work...
Old 01-03-17, 12:00 PM
Tom57
Tom57's Avatar
He may have used a hammer on the old hub where you used a hub/gear puller > your step 7 & 12 in link.
Old 01-03-17, 04:46 PM
rkw77080
rkw77080's Avatar
Aah, the rusted-in parts... Sometimes things that are seemingly irrelevant can turn out to be the most difficult part of the project.
Thanks for pointing this out. I'm glad I didn't have to deal with that problem.
Old 01-03-17, 09:01 PM
toantran99
toantran99's Avatar
Did you connect the abs sensor back to the wheel bearing?
Old 01-04-17, 12:11 AM
svlexus
svlexus's Avatar
Everything went back together, I did pry on the wrong part of the sensor cover and slighty ovalled the hole. No abs codes, and I dont see the light,it only happens during a slow right turn, but then again I dont hit the brakes during turns except in parking. It started the day after I did the rear hub and installed new lexus brake pads.
Old 01-04-17, 04:00 AM
rkw77080
rkw77080's Avatar
To confirm... Did you say you can hear rumble while making a right turn even if you are NOT hitting the brake?
Old 01-07-17, 06:45 AM
svlexus
svlexus's Avatar
No its when braking to a stop while turning hard.
Old 01-07-17, 08:24 AM
rkw77080
rkw77080's Avatar
I suspect that you're not dealing with a speed sensor problem, otherwise, the symptoms would be the same if you turn in either direction since both will generate the same speed difference between the 2 wheels. I would suggest a careful look to find evidence of rubbing.
Israelq95
11-05-18 11:20 AM
QPedro
ES - 5th Gen (2007-2012)
07-25-17 08:10 AM
RevLimit
11-12-10 11:00 AM
cartechpr
05-16-06 06:58 PM
Quick Reply: abs issue after wheel bearing replacement.
