Coolant leaks
Old 12-23-16, 05:00 PM
volson
volson's Avatar
Default Coolant leaks
Hey guys,
where have your cars leaked coolant from? I still have some drips on the lower engine cover and wanted to see what the usual suspects are. I have replaced radiator, cap, large hoses(not trans ones). I also redid the fipg seal on the housing near the top hose.
Old 12-23-16, 06:36 PM
amusing
amusing's Avatar
With new radiator and hoses now investigate overflow at reservoir it will drain down a short tube onto that lower plastic panel also weep at water pump
best regards in getting a solution
Old 12-23-16, 08:20 PM
911LE
911LE's Avatar
Could also be the water pump. Lexus coolant leaves a white residue when it dries so just look for that. Run your finger under all the hose connection points to see if a hose clamp isn't tight enough.
Old 01-02-17, 09:46 AM
volson
volson's Avatar
put the car up a little and took the engine cover off and it seems that it is accumulating and dripping from the middle of the steering rack. I am going to leave it level and keep and watch the drips. I am going to check the service records since timing belt was done 20-30 ago. I wonder if they skipped water pump.
edit: water pump was supposedly done 4.5 yrs and 40k miles ago.
akafixture
12-26-15 10:18 PM
Masticore
03-17-08 01:14 PM
Rolemodel
Maintenance
15
09-22-07 01:30 AM
esandes
Maintenance
14
06-26-06 11:12 PM
ztikmedia
Performance & Maintenance
09-01-03 01:59 AM
Quick Reply: Coolant leaks
