Puddle of Fluid Under Drivers Side Rear? Shock or Bushing? Help!
Pulled out of driveway this afternoon and found a puddle of fluid where the rear of the car was parked the night before. The differential is dry and the fluid is not motor or transmission oil. Would a bad bushing or shock be able to leak enough to leave a spot? It looks to be coming from where those items are on the drivers side rear.
Most likely a shock/strut and mine did the same thing but on the rear, passenger side. At first I thought it was my differential leaking.
Just one day there was a large oil puddle in the driveway.
Check the strut itself to be sure, it will probably be covered in an oil film.
Standard non airbag. Fluid is almost clear with a pretty bad smell to it.
Trying to get a parts list together to do a full suspension upgrade since i plan to keep this car a long time.
Thinking of rsr superdown springs, 30mm rca drop kit in front, sport suspension shocks front and rear, sport rear sway bar and new oem rear control arm bushings.
SMCK
07-06-18 01:35 PM
